Apx4000
Seth4380
looking at purchasing this radio from marketplace. Will any APX4000 work on a regular conventional system. Or is there something I should be looking out for. Looks to be flashcode.
R8206SG314801
Asunakiyori
Lurker
Hiding in a Shed somewhere
I have a wonderful little APX4000 UHF1. works great on conventional. If it's the right band should work well for you as well
I only have one issue with mine and that was either my fault, or a mfg defect and thats the Middle impress data pin broke off
UAT_978
Aftermarket batteries that are designed to be used on XPRs can cause this. The second set of pads can catch the pins and rip them off. Its not limited to the center data pin either. I have had them come across my bench with the outer sets ripped off as well.
Asunakiyori
Lurker
Thats the battery that came with it... the second set of pads
