APX8000
don9ozt
Elk Grove Village, il
I have an APX8000 one of the systems is phase II, Ioad the code plug and it works fine. If I turn the radio off and then back on, or switch to a different system and then back, it will not receive. Any help would be greatly appreciated.
Thanks, Don
KevinC
32D2T/957.282
I'm everywhere Focker!
You won't like this question, but is this radio allowed on the system or are you just using it as a scanner?
KevinC
32D2T/957.282
Kevin,
It is setup not to affiliate with the system, it works through conventional settings.
Don
My guess then is it's siting on a site that doesn't carry the traffic you want. If the coverage type is set to SmartZone this can happen.
Phase 2 will have no bearing on this (assuming it sometimes works that is).
don9ozt
It will work fine all day, the minute i turn it off and back on I have to reload the code plug.
Do you think there is any solution to my problem?
I also use the radio for VHF and UHF ham bands, that works fine.
Is there any way you could look at my code plug?
KevinC
32D2T/957.282
I'd rather not have my fingerprints on anyone's codeplug.
Feel free to post it and maybe someone else will look at it for you.
Project25_MASTR
TX-COMU
Texas
Is this a multi-site System? If so what is likely happening is when you turn your radio on it scans the pre-programmed control channels. Once it finds an active one, the radio will monitor the control channel data and “download” the current adjacent site control channel lists and add it to its flash memory (note, this can not be viewed in the codeplug). Next time you turn it on, the radio is likely voting out the site of interest for a better site which is not carrying the traffic you are interested in.
Check and makes sure the either SmartZone isn’t selected or set your site preference to always for that site in your trunking personality.
