AR-DV1 & Butel software --- USB error?
kf6gpe
Ray, KF6GPE
Boulder Creek, CA
I suspect the problem is with the PC, although I'm not entirely sure. I just got a new AR-DV1 and have installed the ARC-DV1-PRO software from Butel. I've run the driver installer for x64 on my Windows 10 box, connect the radio, and I immediate hear the USB device connected chime and get a popup saying that the USB device has an error. I've tried restarting both the PC and the radio, and in fact even tried a full reset on the radio. The radio's baud rate is set to 115,200, although I don't think that's it --- I think that'd only have an effect after the initial USB connection.
Any advice? Thanks!
kf6gpe
Ray, KF6GPE
Boulder Creek, CA
The plot thickens! I tried using my wife's PC --- installed ARC-DV-1, the x64 driver, connected the radio, and no USB sound whatsoever.
This is a good data cable; I've used it with other hardware.
marlbrook
Devon, UK
Installing AR-DV1 Driver Instructions
Step by Step guide / advice + working Drivers for AR-DV1 connecting. Although created to assist eSPYonARD users, should also be applicable to BUTEL software.
kf6gpe
Ray, KF6GPE
Boulder Creek, CA
Thanks! I'd already tried installing that; tried again, and on my shack PC I see the same USB error; on other PCs I see nothing.
Any other thoughts?
kf6gpe
Ray, KF6GPE
Boulder Creek, CA
I've also tried uninstalling the SILAB driver in the system control panel and re-installing it, and swapped through three USB cables, all of which I know work with other devices.
The problem might be the one reported here:
SigIntel8600
Communications Receiver Nut
Pine Barrens
Yes, here is my WAG, (Wild A@@ Guess) did you install the software an administrator? Also, when you run the software, are you running it as an administrator?
marlbrook
Devon, UK
The download not only includes the SILAB driver version that actually work. Some versions do not.
Did you download my step by step instructions, and follow them exactly? They contain important tips, that if ignored will just result in your P.C. re-installing the same driver you are currently using.
kf6gpe
Ray, KF6GPE
Boulder Creek, CA
Yep --- I followed the instructions step-by-step in your download instructions; no change.
I'll try it again tomorrow, too, to see if I missed a step.
marlbrook
Devon, UK
OK, do not forget to go back and check the newly installed Driver version number is the one I included when the other steps are complete. Good luck
marlbrook
Devon, UK
Forum Rules mean I cannot post this in two places.
So anyone interested in the above, please look at;-
NOT the description of the post shown above.
The later post headed 'DRIVERS AND USB PROBLEMS GENERALLY'
struijs
Any advice? Thanks!
Did you find a solution? I have exact the same. Unit is 2 days old. First day playing with USB. ...
Regards, Peter
kf6gpe
Ray, KF6GPE
Boulder Creek, CA
Regards, Peter
I did not. Jeffery Ashby noted over on the Facebook group for the AOR-DV1 () that it seems that there's a collection of units with bad USB ports. I haven't flipped mine over yet to see if mine is in the affected batch.
I ended up doing the programming with the AOR DV-1 Data Utility on AOR's web site. That said, I just went looking for it for you, and while there's a link on AOR's download site, it appears to be broken.
(edit: Aha, it's AR Data Editor:Help)
That said, if you have a SD card reader, you can save the channel settings and edit them as a TSV in Excel or Open Office.
Of course, none of this should be necessary...
