How can I find out when the track will be used?
dig in and enjoy.
Can be used to see the status of several types of special use airspace (SUA).How can I find out when the track will be used?
Can you please send me the link to the file? The image you attached is small and blurry.Howdy - I use the "SUA" of Special Use Airspace web site as its a very good tool...use can also search NOTAMS, but it is a bit more time consuming. The SUA also shows Military Operating Areas (MOA's...etc..)
1.
Your AR Track Map is dated....attached is this most current (2018).
Hope this helps and I can easily hear the AR work in my area (DFW) when the AR-102 / 104 Tracks are active....a good UHF Mil-Airband Antenna (225-400 Mhz) and higher mast / antenna is better, along with good Coax can improve your reception in most cases too.
A lot of the Tankers I see are based at either Altus AFB or Barksdale AFB(depending on the missions) but other bases too.
If you have a good Antenna set up you with like hear the AR 104 Track and others too...
Hope this helps.
Howdy the file is too big the send and this is the last printable version of the AP/1B. Going forward we will likely have limited or no access...but historically, the AR Tracks on the old document are the same as the new document in your area in general...as noted above, the SUA site is the most current and a lot more data points too. Not sure why your image is non readable. Do a Search on the AP/!B document (PDF) and you will hopefully find it as sometimes not easy to locate as prior...You have several MOA's in the area, and also likely some other "Training Routes" (IR and Slow routes - some high speed routes north west too)...Can you please send me the link to the file? The image you attached is small and blurry.
