v. (6.0007-026) - TO BE RELEASED SOON - For anyone interested here are the changes in the new update:-
1. VFOA and VFOB SELECTION
Changes are significantly faster
2. QDB
Calling Q-DB is much faster
3. POWER DOWN The DV1 was not always powering down when the option was chosen - FIXED
4. PARTIAL RESET
Right-Clicking the small button, top left of the Yellow screen, gives an option to RESET the program to its VFOA settings, if required.
5. USB DISCONNECTION
In the last update I introduced some 'fail safe' coding in case the DV1 lost its USB connection. That did not work correctly. Now if that is ever triggered the Program does not 'close', but gives an option to RESET
6. MANUAL MODE SELECTION
Amended routines called if 'MANUAL OPERATION' has been selected by left clicking the Tuning Knob on the program's screen
7. BAND SCOPE 'S' SELECTION
Added 'S0' option in list on the right of the Band Scope
8. MAIN SCREEN BUTTONS
a. Swapped position of NOTCH and SCOPE buttons
b. Changed position of SCAN and DELAY buttons
9. MONITOR BUTTON
Removed the MONITOR button from main window. Duplicated function so not now needed. Clicking the BAR beneath the Volume Slider gives the same result.
10. BAND SCOPE MARK 'XI'
a. Improved 'ghost frequency' detection and removal during a 'Sweep'
b. Faster Sweep creation time
c. Improved BANDSPREAD creation and execution for SAVED Sweeps
11. BAND SCOPE 'SDRINT' WINDOW (SDR INTERFACE)
Added frequency 'UP/DN' buttons, for convenience
12. ADDED 'EXPERIMENTAL' ICOM IC-R8600 INTERFACE FUNCTIONS
When the 8600 and DV1 are connected via the 10.7 MHz output, shows actual frequency of 8600
if the DV1 frequency is changed in the 'IF' range
13. BAND SCOPE 'SWEEP' MODE / IFBW CHANGE
During a 'Sweep' the MODE can be changed using the buttons at the top of the Scope.
NOTE
The MODE will ALSO change in the 'saved Sweep stored settings'.
If you change a MODE, and do NOT wish the change to be PERMANENT you must change back to the 'ORIGINAL MODE' you wish the program to remember in the 'saved Sweep', BEFORE exiting the current one.
You may change the 'IFBW' using the button on the main window and selecting from the list that appears. However values of '100' or '200' are NOT recommended under normal circumstances as the Squelch will open before reaching the 'centre' frequency, which will cause the Sweep to stop early.
***If the CURSOR is over the Scope's Title Bar, holding down the LEFT mouse button pauses a Sweep, until the button is released
14. AR-DV1 SCAN AN SEARCH FUNCTIONS
These now usually ONLY commence once a selection has been made from the Bank List.
Prior to Rev.6.0007-026 this was not always the case, as the previous Scan or Search bank would sometimes start as soon as either function was selected.
15. SEARCH AND SCAN DELAYS - AR-DV1 FUNCTIONS
I have re-written the Code regarding the control of the Radio's own Search and Scan functions.
As before the 'Sliders' are accessed by clicking the 'DELAY' button on the main window.
The DV1 does not have individual settings for each function, however with eSPYonARD this is achieved, as the Program stores and remembers the 'delay' settings that were selected for both Scan and Search. A value between '0' and '9' seconds.
The Radio has a HOLD function. 'HLD' appears on the receiver's screen (and the Programs' screen') when activated.
The Manual states that setting a maximum delay value (10 seconds), the DV1 will halt on the next 'active' frequency, and not move on until either the delay is changed, or the UP/DN buttons are clicked. In fact this firmware function has never worked correctly, and the scan or search re-commences after 12 seconds.
If 'FREE TIME' is set to '0', a Scan or Search will halt on an active frequency, and not be released until the 'carrier' stops. If a different value (in seconds) is chosen, after that period the Scan or Search will resume even though the transmitting 'carrier' is still present.
16. VFO CHANGE SPEED
Changing between or selecting a VFO is significantly faster
When selecting a VFO immediately after a Memory, Scan or Search operation, the time to change is slightly longer as many parameters have to be reset
17. BAND SCOPE - SELECTION OF SAVED SWEEP RESTORE SETTINGS
Sweep RESTORE option window now appears almost immediately. Previously that could take several seconds. If 'NO' is selected, SCOPE automatically resumes previous sweep, if one was in progress
18. MISCELLANEOUS
Numerous speed and efficiency 'tweaks' to many functions
