Are there any good gooseneck HT antennas?
OkieBoyKJ5JFG
Carrying a radio is a good idea, but having it clipped on your belt really impacts performance, usually about 30dB or more. Us meatbags really suck up RF.
The goose neck antenna would be a concern since it'll put a lot of stress on the radio's antenna connector. Cheap radios will have a harder time than higher tier radios.
Getting the antenna away from the body is the right thought path, but there are only a few options that actually work and don't risk damaging the antenna jack.
All good points. I don't typically put anything on my back on a trail ride, particularly something hard like a radio. Something like that can crush a vertebra, turning a nasty fall into a life-altering event, so it's pretty much going to have to stay on the belt. I can't put it in a saddlebag because in the event of an unscheduled dismount, I want to have it with me (assuming it will still work). I do have a BNC connector on my radio, which should help some, but I also just accept the fact that I'll probably break my radio someday. To your other above comment, I don't need very long range. I'd use a stubby if I were confident I could get 2 miles out of it.
I understand. I kept mine in a backpack I was wearing anyway, and off to one side. I was thrown off the ATV once, and broke my hip socket and cracked my pelvis in 3 places. The radio didn't cause the injury, but that's good thinking if you go straight off the back.
Yes, that's important. Having it attached to me (in the backpack) was extremely helpful since I was the last guy on the ride, and I needed the radio to call them and come back for me. Not having the radio with the rider is a bad idea.
Better than the stubby, go with the 19" long thin whips. That is what I used on a VX-170 and it performed pretty well for a hand held. It's flexible enough to not annoy the person carrying the radio, and it gives you some good range. The stiff/stubby antennas can still put a lot of strain on the antenna connector.
OkieBoyKJ5JFG
That's definitely a possibility worth looking into. Even though it's long, the extreme flexibility might mean it wouldn't poke me or otherwise bug me.
