Arrow Antenna, J-Pole
In my review of the comments posted, I think I'm detecting a discussion of several different antennas going under a general category of "J-Pole."
As Majoco points out, the "J" design is essentially an end fed radiating form of a wave guide, first introduced in the era of the Zeppelins- a long trailing wire of a half wave length radiator end fed thru quarter wave line. Without getting int the theory of this design, it basically follows a folded antenna analogy for an end fed antenna; fed at the centre of symmetry (a half wave section.)
For a "J" antenna, the radiating section length becomes critical. It is at ground potential in relation to the matching section, both of which are impedance tapped to provide a 300-600 Ohm match. But the long element does not form part of the support mast. My reservations with the "J" is a mechanical issue- the construction of a stable matching transform'r, the selection of the proper feed points, and the stable isolation of this assembly from the support structure. This last one, its mechanical stability, is the bear for me; the mast can't be part of the antenna, although there are designs I have seen that do use it as such. Invariably these antennas exhibit high degrees of coupling (unfavorably) to other metallic structures, and their radiation patterns are off the charts.
Which brings me back to my opening- is this a discussion of several antennas all being lump'd under a "J-Pole?" A vertical radiator with a Gamma matching arm looks just like a "J" - but isn't. Personally, I love Gamma matching -with it I can get almost anything to work as an antenna (albeit with some times really Half A*s'd radiation patterns but terrific 1:1 SWR's...)-- but a Gamma match doesn't make it a "J."
I will fall back to my original statement- the necessity of adherence to design... otherwise we are comparing unknowns and getting a wild variety of results.
___________________________________________________
Ok, enuff of the Professor's discourse.... :)
Here's a story of one of my experiences with a "kind'a" Zepp antenna. Since I was talking about 'kind'a J's" I think this is will be okay.
On a project in the Far Far North, we were studying auroral stimulation. One portion of the tests involved flying high altitude aircraft carrying, among other equipment, instruments measuring very very low radio frequencies (<10 khz's.) These planes trailed what can most poignantly be describ'd as a "very Very! long antenna wire, " .... so long in fact Notice to Airmen were filed to warn other aircraft to stay well away from us. This wire- this Cable, had to be of a considerable diameter bronze alloy to trail a long distance behind the aircraft- it was Sturdy!
As luck would have it, on one mission the winch that retracted that cable before landing (but of course it had to be pulled in !) malfunctioned. It indicated to the crew that the entire length had been recover'd-- when in fact,,, well, you can fill in the blanks.
As the plane swept'd over the airfield outer markers, that cable and its attached trailing cone, snached up VOR antennas, runway lights---- Ye god's.. what a bloody mess it made.
Someone (anonymous :) ) had to do a lot of soft pedalling to patch that muck- up... I wonder'd at the time how many Zeppelin captains had to do the same .....
....................................CF
bharvey2
CF, I was wincing early on in you story as I could see what was about to happen. That scenario would be dangerous as all get out to both land and flight crews. Seems it would have been better to find an empty area and drop the entire antenna array, then go land. I wouldn't want a plane that I was in dragging an anchor!!
Yes, that was quite an "adventure"....... smiles **... enhance'd, maybe a tad for the sake of melodrama..... :)
The airfield was military- they expect'd a certain number of-like occurances.... it is in a very uninhabited area (oh geeez, unthinkable to do such a thing in the Lower 48!,) Plus the field's approach was over water/ice.
The winch had a break-away spool, so after taking out only a modest few thousand dollars worth of airfield assets, it detached harmlessly from the plane... :)
That set of missions has never been repeated... maybe for the good of all concerned. I am still afraid to ask (laffing) -if we'd ever get invited back....... :)
______________________________________________________________
**I have become very chary in the use of that word --"Adventure."
.... Roald Amundsen, the Norwegian explorer, first to, and beating Robert Scott to the South Pole,-- when he tried to sell his story against Scott's (who perish'd on his return,) found the newspapers cool to his account- compared to the colourful Scott.
"Where is the adventure in what you did?" they asked (he and his men had return home in good health, without a misstep in their whole trip.)
"Adventure?..."Adventure" is just another word for poor planning" he replied..
I have never liked 'adventures' since.
majoco
Stirrer
New Zealand
Interesting that CF brought up about the Gamma Match. There are many more of them around than you were aware of. (Oops - my English master has just turned in his grave.) Of all the guys (and gal) in the avionics bay, there was really only me with a radio background rather than the company 'black box swapping' training. I came into work one morning to find a lot of guys running around like headless chickens trying to get a customers Boeing 737-300 out the door but they couldn't get the HF to tune - it has an auto-tuner at the base of the insulated leading edge of the vertical stabiliser (the tail!) The night shift had refitted the leading edge and made sure it was isolated from the rest of the structure. "Why is it isolated" I asked - "Because it's an HF antenna" they all said "everyone knows it's just a long-ish bit of wire". I wasn't going to persuade them otherwise, so out came the books and sure enough there was a bonding strap between the top of the leading edge and the tailplane - it hadn't been fitted " 'cos it will ground the end of the antenna" they all cried together. The strap was fitted and all was good. Then I had to find my old ARRL handbook and Orr's Antenna book to show that the actual antenna was the whole of the tail fin even though it was firmly bonded to the rest of the aircraft, the isolated leading edge was a gamma match stub - the tuner changed the electrical length of the stub to match the frequency in use. Hopefully they all went away with a different point of view!
So there you are - any Boeing aircraft and I suspect Airbus too that has HF fitted is a flying gamma match!
I thought I'd said my piece on the subject of "J-Pole" antennas- that is until this afternoon when I walk'd past my friend "Barbi's" desk.
In her book rack was a copy of the ARRL Antenna Book. Curious as to what the ARRL might say about this antenna, I borrow'd it.
Sure enuff; from the book- I'll quote this part of it---
..............................."The are many J-Pole designs available........... One of the more popular variants is known as the "Copper Cactus"....... *
So the name "J-Pole" has been co-opt'd. The designs in this book are "J-Poles" all right-- in all imaginable configurations-
Also I'm in sympathy with those that may be confused by all the ongoing comments.
It ain't your Granny's J-Pole of yore anymore.
* Pg. 15-8, ARRL Antenna Book 22nd. ed., 2011
