Anyone know how to listen to Ashtabula PD? They are listed in he database as using 769.53125 MHZ. Can I just create a favorites list with that frequency? Anything else?
What scanner you using? And 40 miles away not sure if it will pick up from Erie, unless you are a lot closer than Erie and have a good outdoor antenna.
I now see there is a conventional option too. I set that up with Ash PD as the system, and Group 1 as Ash PD Dispatch. When scanning it shows the system as Ash PD, and Group 1 is active. But Ash PD Dispatch doesn't show when scanning. Is this OK? Just want to be sure since I'm aways away, and distance could be a factor.
