Ashtabula Police
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I was making a trip to the Ashtabula area the other day to the radio shop at Route 11 & Route 84 and was hearing the 769 MHz frequency with routine APD traffic, I had the PRO-197 set on search and it was stopping on a NAC of 293 every transmission, hope this helps.
Mike
It does. Thank you very much.
Mike
mtindor
FMP24 PRO USER
The new Ashtabula PD 700 mhz dispatch frequency has been added to the database. I only set the old dispatch to 'deprecated'. I did not set the PD2/PD3 to deprecated though. For those of you who routinely listen to Ashtabula PD and have the old VHF TAC frequencies programmed in, please continue to scan all of the old VHF stuff and let us know if you ever hear them in use in the next 30 days or so.
We won't totally remove the old APD VHF frequencies unless they have actually removed the old VHF radios from service. If they still have VHF radios, they likely still have capability to talk on the old VHF frequencies.
Mike
jack_rt
Haven't heard a peep out of them on any of the vhf channels in about 2 months. I'd guess it's probably ok to delete the old channels.
aimedtoannoy
Geneva, Ohio to Temple, TX
I have had APD on my feed since before I started posting on here. I live in Geneva on the lake and at first All I could pick up was The dispatch parch of the conversations. and occasionally when officers were on the west side of Bula I could pick up a mobile. Right now I added an amp and I am picking up almost ALL of APD. Geneva on the lake is about 10-11 miles away.
From what I was told is that they ditched the MARCS system because they could not afford the yearly maintenance for them and They didnt want to pay around 2K for every radio, I was told they were on the MARCs system for free to see if they liked it ( A Trial run). Now the reason they left the 100MHz Idk, Maybe when they went to the MARCS for a bit(?)
discher
Ashtabula,Ohio
ashtabula city
still no hits on Ashtabula city 700mhz live less then 7 miles from downtown and iam using a pro 197 and a discone anteena and a preamp still noting. thanks mike
W8VFD
Northeastern Ohio
I have heard them on their 700 MHz frequency with my pro-197 a while mobile in the Ashtabula area, they are there, however I think they are only licensed for 30 Watt which doesn't leave a very large footprint
aimedtoannoy
If you dont mind me asking, What area do you live in? So I can understand better of why you can't pick them up. Also what kind of antenna are you using? What kind of powersupply and what is the mAh for that power supply? I live at geneva on the lake and I pick APD up with a GRE super amplifier with a 9v 800mAh power supply. my antenna is placed about 25 to 30 feet high.
discher
Ashtabula,Ohio
ashtabula city
i live downtown geneva iam useing a pro197 and a discone antenna 25-1300 mhz it is mount on a mask about 30ft from the ground. i have used two preamps one is a in-line rs with power supply and the other is aantronix ARA1-15-EQ. with power supply. thanks mike
aimedtoannoy
Sorry for the late reply, I honestley dont know why you arnt picking them up, I live at geneva on the lake and can pick them up even without a pre-amp but i get crappy quality, I get around 70 percent signal with my pre-amp on when apd keys in
