ASP
03msc
RF is RF
The Natural State
Nothing. They’re on AWIN still. Listening to them right now. What scanner do you have?
03msc
RF is RF
The Natural State
Nothing wrong with ASP so it’s on your end. Possible that the CC for your local site changed but ASP is on AWIN for sure.
03msc
RF is RF
The Natural State
Make sure you have all frequencies programmed for the site - all that are listed by the site(s) that you monitor, just in case they changed the CC or something.
kk5pa
Hope Ar.
I updated from here . Also we went to Hot Springs Friday didn't hear any state police troop k or g.. I hear a lot of awin on several sites...Just no ASP...
kk5pa
Hope Ar.
It started working.. I unhooked it for a while hooked it back up and it's working.. same for the TRX-1
03msc
RF is RF
The Natural State
No idea. Something on your end, accidental setting change or some glitch within the scanner I would guess. May never know. At least it's working now.
tvengr
Well Known Member
Baltimore County, MD
Sounds like it switched to a control channel frequency not programmed into the scanner. Try entering all of the frequencies for the sites you are using.
Magnetsteve
Central Arkansas
Got to be something on your end. Several G4's and G5's out there and SDS's receiving ASP with no issue. (K Dispatch) Hot Springs area on both sim sites.
dhobby
Hot Springs, AR
Don't know if this was the reason, but TRX 1 had over 6,700 recordings on sd card. Deleted them and now back and running...
03msc
RF is RF
The Natural State
Certainly possible. Could have been something on there randomly causing a glitch elsewhere. Interesting. Glad you got it figured out.
