Astro 25 S/W Port Selection Issue
SurgePGH
Belle Vernon, PA
ASTRO 25 Mobile Dxxxx, Under 'View' then 'Options' and then 'Port Selection' my only choice is OTAP. I have USB ports available and they can be used with patport and patmob but not with the Dxxxx version. Any help with this would be greatly appreciated.
SurgePGH
Belle Vernon, PA
What are you trying to program?
XTL2500 I have 4 of them providing feeds and want to make all 4 S/N the same for ease of programming changes. I had a good working copy of Dxxxxx but no longer have that laptop.
nokones
Sun City West, AZ
As the above poster mentioned try running the program as an Administrator or download the program again. You can find the V20.01 on the Blue Max 49er website. The CPS will work on Windows 7 (64-Bit) - 11.
You should only have the USB Port as an option providing you are using a RIBless USB cable like the HKN6184 programming cable with a M5 Control head.
clbsquared
Isle of Wight County
You don’t need to change the serial numbers on them to make programming easier. Just do a top level drag and drop. It will carry all of the info from the donor codeplug to the receiving codeplug. Clean up any errors it may give you and you’re done. Easy peasy lemon squeezy
SurgePGH
Belle Vernon, PA
This "D" software.
SurgePGH
Belle Vernon, PA
It's an OCD thing with me. 3 have a custom S/N and one I transposed the first three numbers.
chrismol1
Did you try going into Device Manager see if the cable shows up there to assign it a port, I dunno I'm guessing I have no idea I'm probably wrong
KE4ZNR
Radio Geek
To get the USB option to show up in that software you have to go into compatibility (right click PatPortD then Properties then compatibility tab) mode and select an earlier version of Windows such as Windows 7 or sometimes Windows XP. Once you do that and save it then run it the USB option will show up.
SurgePGH
Belle Vernon, PA
I'll give that a shot when I get back to the house tonight.
