astro spectra programming
specialopsmedic
Salisbury / Charlotte NC
I have an 800 astro spectra that I am trying to read/re-program. I have a motorola RIB, the correct cable, but when I read the codeplug it says I don't have the right RSS/CPS version. Can anyone give me a list of the RSS/CPS for an Astro Spectra. I have the Astro 25 CPS and I am assuming it was programmed with an earlier version. Any info will help.
jim202
New Orleans region
Lets ask the question of which cable are you using to program the radio with?
You can make your own and use the rear DB15 connector. The diagram is in the Batlabs site. Just make sure you use the RIB between the radio and the computer.
The version of CPS I am using is R05.02.00 currently.
jim202
New Orleans region
The latest and last CPS for the Astro Spectra is 05.03.00. It's best to use a programming cable / rib combo. There is a all in one cable out there so no RIB is needed but I have had issues with that one. The programming / RIB combo has worked all the time. The Astro Spectra Plus uses Astro 25 Mobile CPS.
Anderegg
Enter text in this field
San Diego
I was hoping someone could point me in the right direction. I have a small fleet of Astro Spectra radios that need some settings adjusted. They are trunked radios, but I simply need some options adjusted such as display names and scan delay. I've looked all over Google, and can't find anyone able to do my radios. I have an old AstroM RSS, RIB, cable etc, but I don't have an old enough computer to run it on.
If anyone can, or knows a company/person etc that can help, please let me know. I have also contacted the Smithsonian Institue, and have asked them to let me know if they locate a computer, old enough to run my RSS, during their digs for dinosaur bones. :)
I know the whole programming thing is Taboo on RR, but I am not sure where else to find assistance.
Paul
cabletech
Puget Sound
If you having that kind of trouble with the software, then you do not have the correct version.
Daywireless has several shop locations in San Diego and for a small fee they can fix you up.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I have a small fleet of Astro Spectra radios that need some settings adjusted.I have an old AstroM RSS, RIB, cable etc, but I don't have an old enough computer to run it on.
Call Motorola, ask to purchase the Astro Mobile CPS and you'll be all set.
You can run it on recent computers without a problem as long as you're not running Windows 7.
You've already to everything else you need.
