ASTRO trunking
WQAJ741
I have an astro saber that has conventional channels, and the company I am starting work for said I could use my own radio. The issue is that they are UHF trunked...now I heard Astro can do that, but can I have a zone where it is trunked and everything else is still conventional or is it one or the other?
KG4INW
Midlothian, VA
Yes, you can have trunked and conventional in the same radio but in your case, it'll only work if you have a trunking enabled flash with the same type of trunking they use. Do you know what type of system it is? What's your flashcode?
If everything works out, have them program it for you so you'll know it's setup properly.
