After an unfortunate fall the SDS100 is not working, displaying all the known symptoms of the "CSJ". Not really trusting the Uniden repair service after some of the non-sense I have heard, I wanted to try and look into myself. I have the case open and the 4 screws removed from the board that the display is attached to. Ribbon cable is still attached to keyboard on the front cover. Have removed the volume/selector knob, but not sure how to remove the board itself to check the antenna connection. If anyone has any insight into this I'd appreciate a bit of guidance, trying to see if a simple re-solder would remedy the problem or if its more in depth and trying not to make it any worse.
Thanks!
Thanks!
