Scanner Tales: My Programmable Bearcats from the 80’s
I started as a police/fire dispatcher at 18 in 1979, the day after my high school graduation, I had actually been hired two weeks prior but I had to get that diploma before I could start. I had already been a firefighter for almost a year and a cadet for 2 years before that. By then I had had a wide variety of crystal scanners, some tunable VHF receivers and of course a Minitor pager issued by my FD. I also had a Plectron receiver from my FD. My Dad had a couple Plectrons as well as he was on the Fire and Police Commission from the town we lived in and had been a police officer there years back. It helped that our next door neighbor was a Lieutenant (and later Chief) on that PD.
When I started dispatching, I was paired with a veteran dispatcher on the afternoon shift for training; Bob. He had one of those new-fangled keyboard programmable scanners, a BC210. I couldn’t afford one as I was paying for a car, college tuition, rent and girls on not much more than minimum wage but he let me borrow it from time to time.
A year or so later he tired of it and sold it to me and I was in hog heaven. 10 whole channels and no crystals; what was there not to love? I wore out that keypad! Pretty soon however I traded that in on a BC220 and then a friend offered to sell me his BC20/20. That BC-20/20 lived in my car for 3 years as it fit perfectly (more on that later).
I also had a BC250 during this time frame, and there was a group of us that sort of traded various scanners around. I may have either had the same BC250 twice or two different ones at different times, I can’t be sure. Others in the group had a variety of the same genre, like the 210XLT, and some of the JC Penny’s, Sears and Wards versions of the same radios. I seem to recall someone having a BC211 but cannot seem to remember who. I also seem to remember a BC218 scanner along the way.
These scanners all shared a common form factor. They had a sloping front panel we called “The Wedge”, with the volume and squelch on the right side, keyboard in the center and speaker on the left. The back panel had a Motorola jack for the antenna, a spade lug for the 12VDC power, a ground screw, a two-wire AC power jack and an external speaker jack. On the BC250 and perhaps a couple others there was a screw terminal on the back, I seem to recall this was to turn on and off a tape recorder via its Remote jack.
The BC210 had a battery for memory retention so it would not lose the frequencies when you unplugged it. I think the original batch used some sort of coin cell while most later radios used 9-volt batteries. The 210 would not however retain the delay or lockout status when power was removed, but with only 10 channels that was not an issue. Later the 211, 220 and others would retain the delays and lockouts, but curiously (on the 220, 20/20 and 250) not the banks one had selected.
In the early 1980’s programmable scanners were pretty much limited to the base/mobile units. Handheld scanners were pretty much restricted to crystals. I had had a few decent handheld scanners at the time, by then it was pretty much the Bearcat 4/6 (4-bands, 6-channels) for me. I had moved on from my Regency years and really didn’t deal with the RadioShack scanners too much then. I also had had some of the older RCA and Midland handheld scanners in the late 70’s but when the 4/6 and later the ThinScan came out I was converted to Bearcats.
Then along came the BC100. I got one around 1982ish. As I recall it there were a couple iterations of this. The one I had used AA-sized NiCad batteries but you needed a small Phillips screwdriver if you wanted to swap them out, they were intended to stay in the radio and be charged with a wall-wart. Mine also had a threaded antenna connection, and I paid a fortune for it. While later models had a BNC antenna connector and a better battery panel there was no way for me to spend the kind of money to replace it. That scanner was someplace around $400, probably close to $1000 in today’s money.
That BC100 was a decent enough scanner. I took it along on a cross-country Amtrak trip and it performed well, but I just didn’t like it. On the last leg of that trip I had a guy offer me $300 in cash for it on the spot, I took it and when I got home I replaced it with a Radio Shack PRO-30. That had a BNC connector and easier to replace batteries. I still kept my Bearcats in the car and at home however.
In 1984 I got hired as a police officer and now had some extra money to spend on toys. I had pared my scanners down to the PRO-30 for handheld use, a BC20/20 for the car and a BC250 at home. I still had a bunch of other scanners but these were pretty much the daily drivers. In late 1985 I bought a new 1986 Ford Bronco II, my first 4WD vehicle. This car had a pocket shelf above the glove box that I guess was intended for a place to put your sunglasses, cigarettes or some maps.
I brought the 20/20 out to my new car and was trying to figure out where to mount it along with my CB (this was the 80’s after all). I discovered that it fit this shelf perfectly after sticking it in there to get it out of my way when I was contorting myself to look under the dashboard. I was able to reach back and found that there seemed to be enough space behind the back wall of this shelf to run some wires so I decided to put the 20/20 there.
I popped in a Motorola to SO239 adapter into the antenna connector of the scanner and drew on it with a pencil to get some pencil lead on it. I then pushed the radio into the pocket shelf and that marked the spot to drill a hole for the antenna connector. I then used a hole drill just larger than a PL259 sleeve and drilled the hole. I then drilled a smaller hole where the power lug was and ran a power and ground lead thru it. I left enough tail on both the antenna and power leads to allow me to pull the radio out and connect it. The pocket was just the right size to hold the scanner in place with no hardware.
That 20/20 was such a perfect fit for me that it lived in that spot for the next 4 years. I didn’t remove it until I traded the car in and the dealer never mentioned the holes there or on the roof for the antennas.
By the late 80’s and early 90’s the old Bearcat 20/20, 250 and others of that design were pretty much obsolete. I kept the BC220 I had as it was able to filter out the standby tone for the VHF mobile phone systems in use at the time as well as the pseudo-trunking tones used by the Ontario Provincial Police on their 140 MHz. VHF network. As I travelled to Ontario often at the time for railfanning that was pretty important. I don’t think the 20/20 had that filter however so I always had the 220 with me when I went to the Great White North.
Occasionally later on I would end up with another 220, 20/20 or 250 thru a trade or an impulse purchase at a hamfest. They were always great on VHF low band but as they aged they had a variety of issues with power supplies, cold solder joints and keyboard or potentiometer issues. There was a Bearcat repair center in suburban Chicago (Franklin Park) that I could drop a radio off at and they would fix it, often on the spot, but that closed down sometime after the Uniden takeover. I knew a guy who had worked there and he retained some of the service manuals and components for a few years after that. Eventually I moved on to newer scanners, the 20/20 would not fit well in the newer vehicles and 4 years of bouncing around in a Bronco with a poor suspension took its toll. The A/B switch broke on me during a trip so I replaced it with a toggle, that worked well but looked pretty hinky. I considered replacing it with a BC250 but ended up trading in the car before I did.
As for that BC100 handheld scanner, it was pretty much the last Bearcat handheld I had until years later when I got a BC200XLT, another great performer on Low Band! I remember a trip down to the St. Louis area once with that with its stock antenna listening to LA County FD on 33.70 while driving on a steel lattice bridge across the Mississippi River. I kept that for years and had a couple spare batteries, one of those great Metro-West charger stands and a couple different cases. It finally gave up the ghost and I replaced it with a PRO43 in the mid-1990s as that would work on Military Air and I lived next to a Naval Air Station.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
While not a scanner, those Plectron alerting receivers were top-notch. When opened up, you could see that they were a quality product and, in service, very reliable.
Back in the day, I was one of the first officers in a start-up county EMS service with multiple stations. Since the budget was tight, we ordered a number of Plectron receivers and an associated encoder for alerting our stations. Apparently, it was a good decision, since many more Plectron receivers were still in service nearly thirty years later when I retired, even though our primary radio system had morphed into a Motorola trunking system. Given the quality of their products, I always wondered why Plectron ultimately went out of business.
W9WSS
Retired LEO
Woodridge, DuPage County, IL USA
At one point, I had 13 Plectron and Motorola single-channel monitors. 2-3 were UHF, and the rest of them were VHF. I still have 3 in service; One is a red MABAS mutual aid monitor that I can set off the tones, and then open the squelch. I had Mr. Wallace re-program the alert because it would wake up the dead until he minimized the alert tone!Plectrons - Portables 1.jpg
Falcon9h
No one mentioned the BC2500xlt or 3000xlt. The looks intrigued me and I found both on ebay and marketplace recently, finally. Batteries are the issue with these but performancewise they don't disappoint with the rh77ca antenna. And they're nice sized bricks for large hands. Especially good on air band.
Alain
San Diego, California
Gee Rich, I thought you were going to post some photos(!)
Here are some of my oldies...
My BC 210, like others who have posted, still works. Still got the owners manual, copyright 1977. Bought it from the very long gone Speigel Catalog, in Chicago.
Secondly, my avatar is my very first foray into the HF/VHF school of scanning. I found it in one of the old Pop Comm magazine ad's in the back of the magazine. I was made by the Kuhn Radio Electronics Company, In Cincinnati, Ohio. Copst about $50 bucks back then. A lot of money for an 18 year old kid. It was providential that I bought it right out of graduating technical school in '67. The Newark [yeah, that one] riots occurred a month after graduation. I was up several nights in a row listening to the tragedy unfold. Officers threatening black officers over the mobile radios! [yeah, no kiddin'.]
Lastly, was my very first tunable converter, aptly called Tun-a verter. Made in Refugio, Texas.
Read all about it here:
Thanks for the walk down memory lane guys!
N9JIG
Sheriff
Moderator
Far NW Valley
I didn't take a lot of radio pictures back in the day. I had film cameras, digital photography was still a couple decades away for the consumer and while film was relatively cheap, processing was not. Unless yo were using a Polaroid you had to wait for the pictures from the processor. If you brought it in to a local shop you paid thru the nose and if you sent them to Kodak (or heaven forbid K-Mart) it took a week or so for them to come back. I was spending too much money on film and processing train pictures I never thought to take pictures of my radios.
Falcon9h
Used to swear by Kodachrome and swore at it in the digital transition.
Falcon9h
Dead link.
Alain
Falcon,
Me too! I loved that ASA 25 slide film. Great for shooting fast race cars and made great enlargements. I used to have the complete CANON line. I packed everything in a Samsonite suitcase, with a foam insert I made myself.
I had the Canon EF, AE1, FTb, and the Pellix. The Pellix was a very unique 35 mm camera, in that it had a semi-transparent mirror that was stationary! The image went thru the mirror and did not flip up when the shutter was released. It was a great camera for panning with a race car's movement.
Had the Canon 85-300 mm lens and the 1,000 mm lens for the 1/8 mile crashes that became so prevalent in the 1,320 feet drag racing sport.
Can't believe that I did that 51 years ago o_O
ladn
As a newspaper photojournalist, our go to film in the '70's-80's was Tri-X or maybe Plus-X. Color was infrequently used because of the added printing complexity and cost. We didn't use Kodachrome because of the lag time in getting it processed, so we used E-6 films like Ektachrome or Fujichrome. I preferred Fujichrome because of the way it rendered skin tones.
Starting in the '80's, we transitioned to C-41 color negative films from which we could make either black and white prints on Panalure paper or color prints.
We transitioned to digital in the late '90's, first by shooting color negative film and scanning it to digital on Kodak RFS 2035+ scanners. Film processing was done in a Fuji processor like the 1-hour film labs used. Processing time was about 15 min per 36 exposure roll.
I miss the "magic" of black and white printing a little, and color printing not at all. Working with digital is soo much easier.
Alain
ladn,
Being a SoCal resident, you'll appreciate this brief story of mine...
I too was a photojournalist for Car Craft and Hot Rod magazine in the early through mid - 1970's. When I would do my own freelance work, particularly at Orange County International Raceway, "O.C.I.R.", right at the I-5 and I-405 intersection, I would travel the whole weekend, to and from Irvine to San Diego.
Friday's were "qualification", getting the car to acclimate to the track and trying to get into "eliminations" on Saturday. I would photograph race cars all day until sundown. Drive from Irvine to The Photographers Workshop, on Fairmount Avenue in San Diego's Mission Valley. Print into the wee hours of the morning. Drive 15 minutes to get home, sleep a few hours and drive to O.C.I.R. early the next morning to do it all over again.
By Sunday night, when the race was over, I went home completely bushed, but very happy for the work that I had produced...and sold. Then, I had to get up early the following Monday morning to go to my real job.
What were your best work stories?
kc2asb
NYC Area
Great write up and trip back to the past. I've had several Electra Bearcats that were purchased used or acquired through horse trading. My favorite is still the original Bearcat 210. I still have a clean one in working condition. All of the ones that have passed through my hands used the button battery, including one with a date code from 1980. One very early model I came across had the backup battery inside on the circuit board as opposed to the holder on the back panel. The 220 did use a 9-volt for backup.
The Electra Bearcats were soldered by hand in Cumberland, Indiana and Puerto Rico. Cold solder joints and other maladies were common. My 210 does have a hum, but it seems more pronounced on the UHF band.
Sorry for digging up these older threads, but the material is very high quality on the level of a magazine feature. Too bad Popular Communications and Monitoring Times are no longer around. :)
