Setting up an XPR4550 on an Astron power supply indoors. Was planning on programming it down to 1-2 watts (whatever minimum power is) and throwing some sort of back of set right-angle BNC antenna solution on the back, so as to not irradiate the humans sitting next to the rig.
Any issues with this? Not sure how mobiles and handheld antennas match as far as grounding needs go...my only experience is with using NMO no ground plane antenna versions for special cases. Radio won't be used hardly ever, just a backup for if cell service goes down.
Paul
Paul
