Baofeng BF-888S programming
GW7MGW
Llanfair Caereinion, Mid Wales
I down loaded two bits of software to program the Baofeng BF-888S I started with the dedicated software, on reading frequencies it said VHF but showed UHF frequencies on trying to alter I had to change the band to UHF4 [400-470 Mhz] which auto wiped what was on it, so I entered correct frequencies however on writing the radio did a Chinese announcement and sounded a tone.
So I tried CHIRP this did allow me to write the correct frequencies, however the announcement is in Chinese so I returned to the dedicated software, it will read, but not write. So can't find how to get it back to English.
GW7MGW
I have found it does write to radio with the HKT-480 program, but it is selective in what it writes. So clear radio and then read to show cleared which it has, load up saved parameters and re-write to radio, the frequencies have been written to radio but still in Chinese language.
Using current version of Chirp, load the 888 from the radio, on the left side of the screen you'll see a tab for settings, click on that. The first choice in basic settings is to enable voice, the second lets you choose English or Chinese.
GW7MGW
I have tried looking at settings in Chirp, there are no options given, just a blank window. With the HKT-480 Radio Program SoftWare 888 I can save settings, then clear radio, test it is in fact cleared, the load up saved settings, alter to English and up load to radio, it will upload all frequencies but not change language.
I think what I need is saved settings from some one else's radio and try loading them in?
Also some times it goes to transmit without touching PTT.
KK4JUG
GA
What frequencies are you trying to enter? If I remember correctly, the 888s are UHF only.
The tx issue sounds like a problem with the radio, not the software.
Send me a pm and we will figure out how to get my code plug from chirp to you.
GW7MGW
I have been trying to enter the PMR446 group of frequencies, I also tried other 70 cm frequencies, took them out to try today, had to switch them off, as they would without touching them start to transmit. The idea was to keep in touch with my wife while on out push bikes. So I can simply say stop please my chains come off etc. Can use phone in most places, but one has to stop to answer it.
GW7MGW
Thank you to N1GAW I got the file and uploaded to radios, untouched, then switched off and on, still in Chinese and downloading from radios found frequencies had changed to those on your file, but nothing showing where you had all the language settings, and still radios from time to time, go into transmit without touching the PTT and with nothing plugged in, seems these radios are useless, I have it seems bought faulty radios, the Chinese I could live with, auto transmitting I can't.
GW7MGW
You are correct vox is on, however un-tick and write to radio, the read again, and it is ticked, can't turn it off. In CHIRP it is in settings which it will not show. So yes that is reason why it goes to transmit, but can't turn off I will try with head set, maybe less sensitive? I have also tried changing gain for VOX what ever I do stays at 5. I tried changing the file NIGAW sent me to my frequancies and English with VOX off and it changes frequancies but VOX stays on and language stuck in Chinese.
khaytsus
You must have some really oddball 888 device. Mine all work just fine. Have you tried turning off VOX on the radio? Set the radio to channel 1, hold the PTT and MONI buttons and turn it on. That should toggle VOX on or off.
And for english/chinese, same thing but on channel 15.
KK4JUG
GA
I looked at a pair of my friend's 888s and I can't see where they're approved for anything. The OP may have some paperweights now.
(In defense of my friend, he bought a pair when they first came out and had to dig down into the bottom of a box to find them.)
khaytsus
They're FINE for ham use. No, they shouldn't be used for other services. Everyone always has to dredge that up as if nobody knows that.
GW7MGW
Spot on, radios now usable, at last I can use the local repeater again, 73 GW7MGW, ex VP8BKM and VR2ZEP.
P.S. Did upload with HKT-480 Radio Program SoftWare and it confirms VOX is now off, and English voice. Are there any other radio short cuts?
KK4JUG
GA
Okay, I take back all the bad stuff I said. There's a whole different set of rules because I just noticed you're on the other side of the pond.
khaytsus
BF888 BF888S User Manual - Miklor
A few, but those are the most useful ones.. Maybe the scan one, if you want to use a scan function.
GW7MGW
Thank you, just found user manual under the plastic tray in box they came in, and KK4JUG not permitted in UK for transmitting on PMR446 group of frequencies, technically it needs the correct label, however nothing to stop
listening to the genuine PMR446 radios the grand children have, and unlike the genuine radios I can also talk on repeater with same radio.
I don't know what the low power is, don't have adapters to use the VSWR meter so could be over the 500 mW limit, but even if it is, it would not be far over limit, so I would not expect our authorities to really be worried about not having the required label.
KK4JUG
GA
That's fine. When I noticed you were in the United Kingdom, I bowed out because I'm not familiar with the laws there and I certainly don't have a dog in that fight.
