Baofeng Baofeng UV-K6 programming software
Craigmoe
S.W. Michigan
What are the chances that you can take a picture of the Data sticker under the battery and post it here. That way we can eliminate any model confusion. I have the K5, K6, K61 Pro and K67 Pro and all have worked flawlessly with the right cable and CPS. And chirp does have both the K5 and K6 in their lineup under Baofeng. No one has come up with or produced ANY CPS application that allows programming of all the features on the K61 Pro or K67 Pro. It takes alot of manual programming to get these two models to work correctly. Anyway, I look forward to seeing the model on the data sticker. And will advise once posted.
Follow-Up, The Baofeng cable & software wouldn't work on my main programming computer. (attempted several configurations) Tried the Baofeng cable and software on another computer and they worked just fine, no issue.
Will still investigate the problem with my main computer but for now issued resolved and all is
good. Thanks much... C
ladthebad
I have the K67 Pro and programmed it using CPS. Most of my radios I use Chirp. The K67 won't transmit on a repeater though. Do you know how to program it so the offset and duplex is correct for transmitting on a repeater? The program doesn't give me the same options as Chirp does. Thanks.
h_milsom
England
Any further progress with a CPS for the K67 Pro? I'm using the Baofeng UV-5RM PLUS GPS CPS but it has issues - primarily with the frequency range which seems to be password protected. Thanks!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you are having CHIRP issues, see here
Mike
h_milsom
England
I've been playing with a Baofeng K67 Pro using the 5RH Pro GPS CPS and had some success in extending the useable frequency range and installing new firmware. I've made a mistake ignored the warnings; I now have a bricked radio. My error - acknowledged.
Does anyone have any experience of resurrecting a a dead Baofeng or should I just be proud of my new ($25) doorstop?
Regards ...
h_milsom
England
Further information:
The 5RH Pro CPS still reads & writes successfully - but no display.
The radio will enter the Firmware Update Mode and responds to Firmware Upgrading/Downgrading
