UPDATE: Baofeng Squelch Problem CAN BE FIXED
I was able to RECOVER a failed Baofeng BF-F8+ to which I caused squelch problems.
CHIRP will allow a user who is ignorant of the firmware versions to mix versions and cause radio errors.
I am glad that CHIRP development will look into adding a feature to check for version mismatching.
My 1st Baofeng BF-F8+ was indeed defective. The monitor button was supposed to illuminate the LED light on a quick press. Instead of cycling through either a constant-on mode, a flashing mode, or off, the light flickered. The light was sporadic and symptomatic of loose wiring or insufficient LED power. Soon after, the speaker output halted completed but the headphone audio worked. I sent it back for a replacement.
My 2nd Baofeng BF-F8+ worked out of the box. I immediately applied my image through CHIRP from my 1st radio and then I ended up with the squelch issue. I could only hear audio if I held the monitor button down but never checked this before I applied the image through CHIRP.
My 3rd Baofeng BF-F8+ was tested out of the box. All functions worked. I applied the image from the 1st radio and then this one also was unable to receive audio unless the monitor button was held in.
This is where I obtained the information about how to find the firmware version.
This is where I also obtained the original image for that firmware version.
I opened this correct firmware image in CHIRP, then I manually copied over each setting from my old profile, then I uploaded this to the radio. The squelch problem was fixed and the radio works perfectly.
I fixed the squelch issue with CHIRP and a correct original version of the correct image for my radio.
I had no idea that these IMG files were something more than just preferences. I was unaware that it was the firmware image (or something like that) and my setting preferences.
Yes, it would be wonderful if *somehow* CHIRP could warn me that I was about to apply a version "x" image to a version "y" radio, but then again, how would it know if it is only uploading without downloading and then checking and THEN uploading.
Someone was nice enough to publish IMG files for each version.
I researched a document which showed me how to hold in the 3 button when powering the unit on. The display briefly showed the version, in my case BFS297, for one second before continuing with the powering on sequence as normal. I then grabbed the generic blank version 297 image file, opened it with CHIRP, typed my preferences and settings into that profile manually, then uploaded it to the radio. It worked!
Baofeng BF-F8+ Squelch Problem FIX After Version Mismatch
(1) Determine the device version by turning on the radio while holding down the 3 button.
(2) Obtain a clean or functional image of that version for the radio.
(3) Upload that correct firmware version image via CHIRP to the radio.
(4) Test and ensure that the radio squelch problem is now fixed.
(5) Continue to make changes to this specific image file or settings file via CHIRP. Remember not to take an image or version file downloaded from another Baofeng radio and upload to another Baofeng radio -- instead download the ORIGINAL image from each and work within each separately -- they could be different firmware versions even through they look the same on the outside and are the same model.
