Bartlett Tn.
regression
Germantown, TN
Is Bartlett not encrypted? It has been a while since I was last in the Bartlett area.
According to this fire is in the clear. Police dispatch is in the clear but some other talkgroups are encrypted or sometimes encrypted
I don't think I can get Bartlett from my location but the next time I am in the area I will see if I can pick them up.
ka4bni
Dresden, TN
Bartlett is running a Harris Trunked system. Your scanner may need specific settings for a non-Motorola trunked system.
n9pna
Bartlett, TN
Fire and police dispatch are in the clear. What scanner are you using? I used to monitor the system with a BCD436 and had to set the squelch to zero for it to stay locked on to the control channel. Reception seems to drop off outside city limits for scanners. I use a Unication G5 which gets better range and has no problem with the control channel.
n9pna
Bartlett, TN
You will not pick up the Bartlett system from Collierville. Way too far. It is good for 5 to 10 miles outside city limits. You get Millington, Memphis because they are on a county-wide system. Bartlett has their own system.
n9pna
Bartlett, TN
It varies where you can pick it up. I have a Unication G5 that does an awesome job of receiving and decoding. The sites are Yale/Brother (the original site for the old analog) and one in Brunswick area. The antennas for the digital 700 system are lower and have less coverage than the original 800 analog. The out of coverage alert on the G5 goes off when I get to Wolf River headed south on Germantown.
RMason
Mississippi / Colorado
While staying in the Memphis area over the weekend, I logged a different RFSS / Siteid than is listed in the db for the Bartlett site. This won't affect the @ghosty's SDS100, but I believe it could affect Unication users. @n9pna - would it be possible for you to confirm the RFSS.Site you see for the Bartlett site?
# System: Bartlett Public Safety, Site: Simulcast
RFSS . Site
Current db: 1.1​
DSD+ : 10.10​
Code:
Network: 92809.00A  ; Bartlett Public Safety
  Bandplan #0:   Base=772.        Offset=+30     Spacing=6.25  BW=12.5
  Bandplan #8:   Base=772.        Offset=+30     Spacing=6.25  BW=12.5  Slots=2
    Site: 10.10  NAC=00A
    Channel 0-155:    772.96875    CC
    Channel 0-235:    773.46875        SCC
    Channel 8-470:    773.46875-1           VOICE
    Channel 0-355:    774.21875        SCC
    Channel 8-710:    774.21875-1           VOICE
    Channel 0-427:    774.66875        SCC
    Channel 8-854:    774.66875-1           VOICE
    Channel 0-467:    774.91875        SCC
    Channel 8-934:    774.91875-1           VOICE
thesoundman2004
I see the same thing running SDRTrunk from my house. RFSS and Site are both showing 0A[10].
n9pna
Bartlett, TN
Your SDRTrunk info is correct and matches what I am running on the G5. My G5 was initially programmed by a radio shop locally. The info should be submitted to the DB admin for updates.
RMason
the database has been updated.
