Base Antenna
RISC777
There's a number of options. Internal, such as an attic if you have one, external on a mast, etc. Info you've left out of your question are what freq ranges are you wanting to monitor, distance from sources, 'flat' land or 'hilly/mountainous,' house or apartment (impacts what you can put outside), and such things. Budget?
trustnoone
Im in southeast Kansas (flatland) and own my house so I can put any antenna up. The Police around here are mainly in the 155.000 range and I dont want to spend more than maybe $100.
RISC777
hmmm....okay.... an Atennacraft "Scantenna ST2" antenna (omni-directional, ships with 50' RG-6 cable - not counting delivery can run as low as $30-ish - Stark Electronics or/and Universal Radio), a mast of some kind to get you some height, but mind your total distance from the antenna to your scanner and where you're able to route it (ground the mast to earth ground with some decently thick bare copper and a ground rod hammered in/down, not a service or 'house' ground). Mast can be pipe from hardware store; how you attach to the house is your call (there's numbers of ways to do that also). Putting the ant in the attic, if you can, keeps it out of the weather and wind, but decreases potential height gained by utilizing a mast.
Just some $0.02 thoughts and input/response(s).
Winnsboro, La
Reply to Base antenna
I used two 11.5' lengths of chain link fence top rail bolted together with 2 stainless steel bolts purchased at a hardware store. I used a length of RG58 with solderless PL-259 connectors at each end with an BNC adaptor. NOTE: you can put a little solder on the center pin after assembly or carefully crimp the end of the center pin. You can also use a twist on BNC connector on 1 end of the cable. I also use 2 $25.00 base antennas from Radio Shack ( not sure of part # right at this time ). I have 1 antenna at 23' and 1 at 35' and can pick up signals up to 60 miles away or more. HOPE THIS HELPS.
Hoofy
Laurium, michigan
You should probably take this to the antenna forum and specify what freqs you're most intrested in listening to. The freqs can make a big difference in the type of antenna you need.
ltbfd
Littleton
I'm using a par-mon3 from Universal Radio and it is working very well in all bands. I have it mounted on 2 lenghts of mast from the gable end of my house. so it's about 30 ft up. pulling in VHF- hi and UHF from about 50 miles away and I'm in a valley type area in Massachusetts.
kb2vxa
Banned
Point Pleasant Beach, N.J.
Hi all,
When it comes to mast I avoid HW steel because it's soft, heavy, bends easily and uses threaded couplings, a nasty weak spot. I use one of two sorts depending on circumstances. HW aluminium EMT avoiding those threaded couplings, each smaller diameter slides inside the larger about a foot, pin and you have a fairly light tapered mast. Another is the famous Rat Shack medium wall steel with swaged ends that fit together. Any way you look at it GUY IT if you're going over 10 or 15' above the uppermost support, less if you're using a beam and rotor or large and heavy antenna of any sort. Avoid possible contact with power lines, blah blah blah...
One important note, the National Electrical Code (NEC) requires the ground wire not to be less than 6AWG copper and all earthing rods to be tied together and connected to the neutral bus inside the electrical service entrance panel with the same. This reduces the difference in potential between them during a lightning strike which can easily be in the multi-kilovolt range. Avoid sharp bends, lightning has a nasty habit of leaving the conductor at these points causing a nasty flashover to whatever alternate path to earth it can find. By all means avoid that aluminium "grounding wire" because it weathers badly and in a few years becomes brittle. Once I removed a 6M antenna from a widow's house and after only 10 years that miserable stuff broke to pieces at the slightest touch.
sony
For base station get Channel Master Antenna. Mobile Antenna Specialists Mon. 51 ..
