Cbman417
hello im looking for a good base scanner antenna that can receive will and transmit on 27 mhz. thank you....
If you transmit on your CB when the scanner is connected - you're going to fry the scanner.hello im looking for a good base scanner antenna that can receive will and transmit on 27 mhz.
not if the scanner is not hooked up to the coaxIf you transmit on your CB when the scanner is connected - you're going to fry the scanner.
Antenna Broad Band Discone Scanner Base 25-1300 MHz. Tram 1411
Right. He didn't mention using a Diplexer. Wonder if that's in his budget?You can use a diplexer and transmit on the CB while receiving on the same antenna at the same time. There are a number of diplexers that have a port for HF to 30MHz for the CB, then another port that takes over
What's that got to do withUniden BearTracker 885
??im looking for a good base scanner antenna
Uniden BearTracker 885 Police Scanner | ScannerMaster.com
Uniden BearTracker 885 police scanner, is very simple to operate, you can be up and running in 3 minutes or less.www.scannermaster.com
