Bay County P25 (00A.924B5)
medic9351301
Banned
here are the tower sites in case anyone is wondering :
Simulcast from 3 locations: West End Fire Department, BC Traffic Signals Department, and FL Route 20.
n4cfd
lynn haven, fl
After reading some of this forum, I am beginning to understand what happened on 8/12/21 to my bds436 and whistler 1040. Sometime in the evening I had no reception on either scanner and to this day I only get sporadic activity. I am a newbie at this and would greatly appreciate any guidance anyone could give me. Do I need a new scanner? Thanks for your info.
medic9351301
Banned
your 436 should work just depending on your location , if your getting what sounds like garbled talking then you might need to upgrade
the whister will not do phase 2 traffic.
bravo14
Polk County FL
On Freq side this is what I got looks like 8 Control Channels. I'm seeing 7xxx the past week or so not hearing much just plan talk or testing.
Network: 924B5.00A ; BAY COUNTY P25p2 PUBLIC SAFETY
Bandplan #0: Base=851.0125 Offset=-45 Spacing=12.5 BW=12.5
Bandplan #8: Base=851.0125 Offset=-45 Spacing=12.5 BW=12.5 Slots=2
Site: 10.10 NAC=00A ; BAY COUNTY
854.3625 CC SCC VOICE DATA
854.3625-1 VOICE
854.3625-2 VOICE
854.4125-1 VOICE
854.5125 CC SCC VOICE DATA
854.5125-1 VOICE
854.5125-2 VOICE
854.8875 SCC
854.8875-1 VOICE
855.1375 SCC
855.1375-1 VOICE
855.6625 CC SCC VOICE DATA
855.6625-1 VOICE
855.6625-2 VOICE
855.6875 CC SCC VOICE DATA
855.6875-1 VOICE
855.6875-2 VOICE
856.1625 SCC
856.1625-1 VOICE
856.3125 CC SCC VOICE DATA
856.3125-1 VOICE
856.3125-2 VOICE
856.7375 CC SCC VOICE DATA
856.7375-1 VOICE
856.7375-2 VOICE
856.7625 CC SCC VOICE DATA
856.7625-1 VOICE
856.7625-2 VOICE
857.2625 SCC
857.2625-1 VOICE
857.2875 CC SCC VOICE DATA
857.2875-1 VOICE
857.2875-2 VOICE
857.7125 VOICE
857.725 VOICE
858.0125 VOICE
858.025 VOICE
bravo14
Polk County FL
These are not related to the system some how they got into the data plan for the system. I have to delete them again.
857.7125 VOICE
857.725 VOICE
858.0125 VOICE
858.025 VOICE
fasciglionerj
Panama City, Florida
Good day all - I used to monitor Bay County Public Safety but now can not.
I have two BCD536 radios and it's all silent. Reading these threads here, I see that the P25 system for BC Public Safety was changed from Phase 1 to 2 recently. Could someone provide steps to re-tune my radios for BC Public Safety? I am new to all of this but I would like to learn more about scanner programming. I appreciate all the information everyone is providing here.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
(EDITED)
your radio will have issues with P25p2 simulcast transmissions --- it may require some creative antenna work. I would try with an indoor antenna.
you will be better served to upgrade to the SDS100
doug
bravo14
Polk County FL
There is cases where the "T" does drop to the "D" not sure if you got all freqs listed on rrdb. I use to have the 536 years ago no longer have. The sds100/200 does very well with the system I do hear them with no issues.
maus92
OCMD
your radios cannot demodulate phase 2 P25.
you will have to upgrade to the SDS100
doug
His 536 can receive P25 P2 - I'm using one right now on a simulcast system in Maryland. But it depends on the system design, his location relative to the system's transmit sites, and his receive antenna. Add in that Harris P25 systems are notoriously difficult to receive - even with subscriber radios - and it's not surprising he is having difficulties. He can attempt all kinds of mitigations: attenuation, yagis, paperclips for antennas, relocating the scanners even a few feet, but I think your advice to acquire a SDS radio is the best solution.
batdude
Moderator
you are correct - i have no idea why I typed that. What I meant to say was "simulcast". I'll correct the post.
doug
marksroberson
Florida Panhandle
The system can adapt to both Phase 1 or Phase 2.
Bay County Sheriffs Office and Lynn Haven Police have Harris radios for sure.
Those are programmed for Phase 2.
Fire departments use Motorola radios, PCPD uses XTL2500 in their cars. they are programmed for P25.
That's why my scanner (that's only capable of Phase 1) can pick up 1 snippet of a conversation on SO dispatch.
It probably just means that they have a Motorola radio they are talking on at the moment.
So yes, they can switch back in forth depending on what is being used. We will see how well the system holds up once they start installing more towers, I think there will be 7 total.
Don't know how that needs to be expressed on the RR Page, but places like the airport, PCPD, and fire is almost 100% P1. other TGs are come and go depending on the subscriber radio, thats what probably needs to be changed.
maus92
OCMD
Depending on vendor licensing, running a mixed P1 / P2 system can be inefficient. I’m wondering if some agencies are running new P2 portables are retaining the P1 mobiles until the host vehicle is replaced? That strategy saves a bit of money in the short term, and spreads purchases out over several years. The issue is when a P1 mobile transmits, the system has to find an unused fdma channel and reserve it, which could tie up resources when the system is busy. OTOH if the system was originally fdma and they did not give up any channels when converting, prob not an issue.
bravo14
Polk County FL
On phase ll side for audio is low when on phase l it is very loud don't know what causes that. It is on both on sds 100/200.
bravo14
Polk County FL
So for for Encrypted TGs & Date
1026 BCSO ENC 1/15/21
1028-1030 BCSO ENC 1/15/21
4004 PCBPD ENC showing up on 9/3/21
6012 LHPD ENC 3/9/21
marksroberson
Florida Panhandle
I rehoused a Minitor 3 today and noticed that the 155.925 paging frequency no longer includes the voice portion of the transmission. Not sure if this is temporary or not, also, the CC today appears to be 857.2625.
so, any ideas if the paging method is going to change or if this is temporary? I just got back into town so I don't know how long it has been going on. I know there is a TG for VHF paging, but my scanner is so weird, I haven't listened to that side yet. Just like how the UHF EMS repeater is off-air but there is still a TG for it on the system, I am hoping its temporary.
bravo14
Polk County FL
I'll fire up the sds100 see what I hear on FTO. I haven't messed with the radios in 2 weeks been busy either working or playing disc golf.
bravo14
Polk County FL
As of the past hour I'm on hold on FTO VHF and hearing the tone & dispatch.
marksroberson
Florida Panhandle
Bay county just had to replace the equipment for that 2 days ago. My boss and I had to run by PC station 1 and get their station alerting going again. Apparently the paging voice audio was very quiet before but now it is back to normal, that’s also why you now hear a Morse ID on the frequency, new equipment.
