BC125AT: BC125AT step rate for frequency
oaktree_b
I want to change the step rate between frequencies on my BC125AT, but not sure if you can. I want to try and tune in some Russian cubesats that transmit at 435.29 and 435.89 mhz, but the BC125AT can't tune that specific value, the closest I can get is 435.8937 mhz for example. I'm in Canada, so it has what I assume is North American frequency spacing.
Can you even do such a thing on the 125AT? I've only seen videos on the XLT, which don't seem to match the menus on the 125AT.
wtp
Port Charlotte FL
Canada Band Plan FREQUENCY (MHz)
LOWER UPPER STEP (kHz ) MODE
25.0000 27.9950 5.0 AM Petroleum Products & Broadcast Pickup CB Class D Channel Business & Forest Products
28.0000 54.0000 5.0 NFM 10 Meter Amateur Band VHF Low Band 6 Meter Amateur Band
108.0000 136.9916 8.33 AM Aircraft Band
137.0000 174.0000 5.0 NFM Military Land Mobile 2 Meter Amateur Band Military Land Mobile VHF High Band Federal Government
225.0000 380.0000 12.5 AM Military Air Band
400.0000 512.0000 6.25 NFM Miscellaneous Federal Government Land Mobile 70 cm Amateur Band UHF Standard Band
wtp
Port Charlotte FL
was cut off of the doc's post
USA Band Plan
FREQUENCY (MHz) D
LOWER UPPER STEP (kHz) MODE BAND
Scan125
UK
Not entirely relevant but with the UBC125XLT, UBC126AT and AE125H (UBC125AT derivatives) you can change the step value for the various frequency bands. Supported step values in kHz are: 5.00, 6.26, 8.33, 10.0 and 12.5. You can also change the modulation: AM and FM (narrow no wide FM).
