dabigdog
OK, I've finally brought myself into the world of "modern" scanners (had an 800mhz radio shack scanner from about 18 years ago).
I've just received this new BC246T but have two questions.
- First, before paying for any software, I'd rather use some free software if it will do the job (manually programming is out of the question!). I've downloaded the available software at Uniden.com and installed it on my PC, hooked up the scanner, entered some information and chose "write to scanner"...it's obviously cleared everything else off of my scanner, but that's all i have now...an empty scanner it appears. What am I doing wrong with this software (obviously it's communicating with the scanner as I can control the scanner from the PC as well)?
- Second, when programming frequencies for 800mhz trunked systems (such as Rowlett PD/FD in Dallas County, TX - http://www.radioreference.com/modules.php?name=RR&sid=36 ) first off, which "system type" do I choose? The referenced link indicates it's a Motorola Type II Smartnet, but I've chosen both Motorola 800mhz Type 2 Standard and Splinter and entered some sample frequencies w/o success. Also, since this is a shared system with Garland and Sachse, how do I block out their traffic, in other words, is there a place to enter the DEC and HEX codes?
Thanks in advance guys,
Dabigdog
Dabigdog
