BC250D
Aircargo
North New Jersey
Anyone care to share there set-up and experences with the bc250d. had mine since x-mas. you can see my set-up below...
I can NOT monitor beyond 36 miles in trunking mode thou...with roof top. pretty sure with distance cause i took scanner mobil towards (south)the area i was trying to monitor. Any help there....?
W4KRR
Coconut Creek
I used to have a 40 foot tower just for scanning. I couldn't hear beyond about 25-30 miles, tops. This wasn't using a Bearcat BC-250D scanner, but that shouldn't matter. 800 MHz systems aren't designed to transmit great distances without multiple tower sites. I would say 36 miles is great. Now, for VHF low band, I could hear around 90 miles, sometimes, not counting skip. YMMV.
K2KOH
Silent Key
Putnam County, NY
A lot of factors go into this. I have several 800 MHz trunking systems in Dutchess County, and two systems in Connecticut. The Fairfield North system in Connecticut is marginal to say the least, with a discone 20' up an RG6. Litchfield South system is half scale, but reliable. NYCOMCO Millbrook is the only Dutchess EDACS site I can access...Beacon, no good, even though it is only twenty miles away.
What systems are you looking for from Newark?
Aircargo
North New Jersey
newark and the surrounding areas i can monitor without a problem...only TRUNKED system i have (freq.) in scanner is trooper on turnpike...troop b....which is like from g.washington bridge to maybe woodbridge IF THAT.
i havent REALLY look around for trunked freq. cause theres so much to listen to in conventional here. alot of PD depts around me are not trunked
i just wanted to hear about bc250d...i always see posts on the pro-95....i clearly feel the bearcat is a better product...i returned my pro-95 week after getting it. bearcat feels even better...the case...screen...ect.
jimv
BC250D and Distance
I use a 250D connected to a Maxrad 850 MHz yagi antenna through low-loss LMR-400 cable and I receive the Washington, DC Fire Department system crystal clear at 40+ miles away.
Aircargo
North New Jersey
pretty clear huh. i monitor pretty good...distance is good. would like to get more distance thou....
any ideas? AMP?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
A yagi mounted to a rotator to aim directly at the site you choose to monitor.
Won't an amplifier magnify the inter-mod in your area?
Saint
Fort Erie Ontario Canada
I've had my bc250d for several months, got mine as soon as the scanner went on the market. I live in Fort Erie Ontario Canada, about 20 miles from Niagara Falls Ontario.
I get out around 20-30 miles give or take
,Really like the scanner and the digital, lot of digital frequencies in this area. I find it a little big to strap on your hip but it's understanding having the digital card and all the other things, I just ordered a Icom r5 today, so I can use it to take out with me it's a very small scanner compared to the bc250d no digital but at least it's small.
Steve
