BC296 Programming help needed
grossmanms
Bay County, FL
I bought a BC296 and I'm a bit confused about programming. I have the 13 800mhz frequencies for Bay County, Florida....but I am not quite sure how to set the scanner up to scan them in the trunked mode. I programmed all of them in Bank 1, but the only way I can hear them is in the ID Search mode. When I am scanning, I can see the ID numbers, but don't hear anything. Could someone give me the "Trunking for Dummies" quick version and tell me how to program my scanner so that I can scan all the Bay County PD's?
Thanks,
Mike Grossman
michael.grossman1@navy.mil
duckbird
Texas
Programming The BC296D Scanner For Trunking)
Press Menu
Press 2 twice
Select Bank
Press E
Press 1
Select On
Press E
Select System Type
Press E
Select Channel Number
Press E
Press 1
Enter Frequency
Press E twice
Use VFO knob to move to next channel
Press E
Press 1
Repeat steps 14-19 (When finished, Press Scan)
Adding Talk Group ID's and Alpha Tags
1. Press Menu-2-2
2. Select Bank-Press E-3
3. Select Location-Press E-1-Enter ID-Press E
4. * Press 2-Enter Alpha Tag-Press E
5. Press Menu
6. Repeat Steps 3 through 5
7. When finished, Press Scan
*Using vfo knob, enter alpha tag (To space forward use the RSM key)(To backspace use the Man/Hold key
