I can understand the point on the radio I picked but to me I want to learn and be able to have something that covers it all.
I honestly just heard about Proscan when someone mentioned it on the forum. I will need to understand what it is and if I can run it on Parallels, does it override programing on scanner done in Sentinel and what all it does better than Sentinel.
"Covers it all" is pretty nebulus in the scanning world since you're dealing with
both frequencies and modulation. The SDS 150 needs
entitlement keys, purchased at additional cost, for some of the digital modes--but it's just flushing $$ down the drain to enable modes that aren't in use in your area or for agencies you have no interest in monitoring.
ProScan is a compressive application that can program the radio, control search functions and redistribute scanner audio via IP.
You can inquire about Mac functionality via the like I provided.
The software will allow you to export the scanner's programming (including frequencies, lockouts, searches, charge settings, etc) to your computer, as well as adding new channels. Typically, the first thing a user should do when using this software is the "read" the radio and save the data as your "base" configuration file. That way, if something gets messed up later, you can always reload the base config and start over.
