BC780 LTR PROBLEM
triryche
Marinette County, WI
I have a question for our Trunked LTR listeners out there:
I have successfully tracked several LTR systems using the BC780 in the past. I am working on a new system with a strange occurrence happening. I have the LCN for the 1st channel of a 3 channel system. I have it properly programmed in the correct channel of the bank to match LCN which in this case is Channel 2. The 780 stops and shows an LTR ID when a transmission occurs but audio is only present for 2 seconds then audio stops and will not resume until the carrier drops and restarts. Then the same thing happens again... 2 seconds will be fine and it drops. I have another scanner on the frequency in conventional mode and the audio is 100% with no drops. It just seems to be losing it in trunked mode. It quite often also fails to stop scanning when there's activity on the system. Signal strength is near 100% solid.
The system is being tracked 100% using a BC246T from the same location.
Anyone have any ideas? This appears to be a regular old LTR system that
we're used to or is there something on newer systems that keep the scanner from tracking?
Thanks in advance,
Mike K9DRX
www.qsl.net/k9drx/
