BC996P2 Driver Issue
SVFC462
Connecticut
After reading all the above posts i am not seeing the answer i need .. yet.
So i received the BCD996P2 scanner today into my work so i can do some testing and playing with it before i pass it along to my customers. I have tried to program it with FreeSCAN & the ARC-XT Pro; both unable to find the scanner that is connected to the computer with a different USB port unlike the BCD996T & XT style. It is a USB serial port similar to a digital camera.
I have looked at the driver and it says "The drivers for this device are not installed. (Code 28)".
What can i do?
wise871
N.W. Florida
What can i do?
UPMan just posted a link to the serial drivers.
BCD996P2 < UnidenMan4 < TWiki
As far a s programing software, I don't believe they have been updated yet.
UPMan
In Memoriam
Arlington, TX
I posted this in the thread dedicated to the BCD996P2. Drivers are at BCD996P2 < UnidenMan4 < TWiki
AFAIK, ARC is updated to recognize the model. Other software authors are still working on modifying.
Butelsoftware
Dayton Hamvention
What can i do?
Make sure that you installed ARC XT PRO V2.0 and the Uniden device drivers.
Gommert
Butel Software
phask
zanesville
Look on that pager under the header:
Serial Drivers for USB
Then it's a zip file with 2 files - copy them to the desktop.
Plug in the scanner -
Find it under com setting.
Force to load above drivers if it does not do it on it's own.
- in the other post you said you couldn't get them to work - and here you can't find them???
verhoffj1
Lakewood Washington
I have No Idea how to force load drivers.. I am not even sure those are drivers I cannot do abything with them.. I am lost.
verhoffj1
Lakewood Washington
The Driver for the BCD996P2 serial port is not installed. Install the Latest driver for the device.. Already followed upman's link for the drivers and restarted my computer.. I have never had issues Installing a driver before today. Error says BCD996P2 doesn't have a driver.
verhoffj1
Lakewood Washington
What can i do?
I am having the same issue! Its very frustrating too! I do not get it.
tampabaynews
Keeping your PIO busy
Florida
I can certainly see how people might have issues installing this driver manually. What is so difficult about releasing it as an executable file? I've done my share of driver work and this is a first for me...
What I did on Windows 7. May work for others...
Download the zip file. Extract it. Place both files on your desktop.
Open Device Manager. Right click on the Comm Port/BCD996P2 device. Select Update Driver Software. Select Browse my computer option. Select Browse. Select your Desktop. Select Next...
Good luck.
verhoffj1
Lakewood Washington
I can certainly see how people might have issues installing this driver manually. What is so difficult about releasing it an executable file? I've done my share of driver work and this is a first for me...
Good luck.
Thank you very much!!!! It worked!
CAR44
CONNECTICUT
Driver for 996P2
I just recieved a new 996P2 and I was hoping to use it on a trip for the holiday and cant get the driver to load. Ive tried 2 computers with no sucess. I see above that this topic amy have its own thread and cant find it. I apoligise if I am posting in the wrong forum but have read everything I can find and nothing seems to work.
