BCD436HP/BCD536HP: BCD-436 SD Card Error
Deadguy
Here and there...
(Please bear with me. I just had a pretty significant surgery and I am on pain meds. This is definitely affecting my typing and speaking skills!)
I have a well used...but well maintained BCD436. Recently when I tried to program the scanner using the Sentinel Program I found that the SD card in the scanner bit the dust. My computer running Windows 10 no longer recognizes the card. I took the card out, put it into an aftermarket reader, attached it to my computer, and still got the error. This tells me that the issue lays in the SD card itself.
Now here is my problem, I installed a new SD card into the BCD436 and I still can't program the SD card to the scanner.
What can I do? I really don't want to trash an otherwise perfectly good scanner over a $25 SD card. Any help and advice is GREATLY appreciated. Thanks in advance.
dave3825
Suffolk County NY
Don't sweat it. Very simple fix.
Did you open Sentinel and select "clear user data"?
ofd8001
Louisville, KY
Lastly, do a "Write to Scanner" so that the database, Profile and any Favorites Lists are written to the scanner.
If possible, it is best to do this in a card reader connect to the computer. Then re-insert the SD card in the scanner. (If you are having trouble typing, it might be challenging to get the SD card seated and the metal retainer "thing" to secure.)
Deadguy
Here and there...
When I hook up the scanner and turn it on, I get to the spot where I can normally write to the scanner, but I get an error that says, "SD card read error" on the scanner screen. At this point the scanner freezes. I don't think Sentinel even gets a chance to read what is on the card and I can't clear the user data. Does this make sense?
Is the radio going into mass storage mode and the SD card mounted in Windows?
Or, is it mounted via the card reader?
Format the card by using the below - recommended by Uniden.
SD Memory Card Formatter for Windows Download | SD Association
Then, do the clear user data to initialize the card for use in the radio.
Thank you for the program. I downloaded it, but it freezes and I can't format the SD card. I really think that the SD card is toast. I ordered a new 8 gig SD. It should get here on Thursday.
Now my question is, are there some sort of batch files (I may not be using the right term, but I think you know what I am getting at.) that I need to download to make a brand new SD card work for my BCD436? If so where can I find them? Surly I'm not the first person to need a new SD card for a scanner!
Also, thanks to everyone. I am so stoked for the help!
ofd8001
Louisville, KY
Yes. Those batch files are loaded when you do the “clear user data”.
1 format card
2 clear user data
3 write files to scanner
That simple. Do not overthink this. That’s when problems happen.
bigbear518
Missouri
Found a way to fix the SD card error on the BCD536 if you cannot do it with Sentinel or by formatting the SD card in a card reader. I found this out when I had the dreaded SD CARD ERROR show up on my scanner. Following are the directions to what took me several hours to figure out but it worked.
Here we go:
1. Be sure scanner is turned off.
2. Connect programming cable from scanner to your computer.
3. Open Sentinel
4. With scanner off, PRESS and HOLD SQUELCH KNOB and turn the scanner on while continuing to hold SQUELCH.
As the scanner powers up, you will here a beep. Let go of the SQUELCH KNOB and your display will read
USB MASS STORAGE.
5. Go to Sentinel
6. Once in Sentinal got to TOOLS and select TARGET MODEL. From the list select BCDx36HP.
7. Then go to SCANNER and select CLEAR USER DATA. Your Scanner and SD card should show up now in the box in
center of the screen, click OK.
8. Follow the on screen directions as they may appear.
9. When that is done, go back to SCANNER on the menu. and Select WRITE TO SCANNER.
10. When the box pops up on screen it will show the SD card and Scanner information. Select both, ERASE
FAVORITES LIST ON SCANNER and FORCE WRITE FULL DATABASE options and click ok and let it do its job.
11. When its done power off your scanner and unhook your cable. Then power your scanner back on and it will show that its updating
then go to right to scanning.
Hope this helps. I know how frustrating it is fighting with it for several hours. This seems to be a lengthly process but it worked for me.
GOOD LUCK!!
C.J. Pekarek
n1chu
Farmington, Connecticut
Several hours? Most would jump in the car and head to the store, buy a new SD Card and get back up and running in less time! Just sayin…
dave3825
Suffolk County NY
USB MASS STORAGE.
Where did you get that from? Other than plugging the cable in, there are no additional steps to enter mass storage mode.
donc13
Grand Junction, CO
Here we go:
3. Open Sentinel
USB MASS STORAGE.
5. Go to Sentinel
GOOD LUCK!!
C.J. Pekarek
That's a lot of work and time when all you had to do was Reformat the SD card and reinitialize it with Sentinel and download the latest database and reinstall your favorites via Sentinel. Maybe 15 minutes worth of time.
Ronaldski
MI DB Admin
Bay City MI
Uniden BCD436HP Police Scanner | How to Replace SD Card
Uniden HomePatrol Series Scanners | Reformatting SD Card- did it on a home patrol II, but same procedure for a 436hp
I will add from instructions above
6. Once in Sentinel got to TOOLS and select TARGET MODEL. From the list select BCDx36HP
fxdscon
¯\_(ツ)_/¯
USB MASS STORAGE.
As mentioned by @dave3825 above, there is no need to hold down the squelch knob to enter the mass storage mode. Your post is the first and only time it has ever been reported as being a necessary step. Many of us here on RR have been using the Uniden SD card scanners since the Home Patrol 1 was released 14 years ago and have never had to use that step to enter mass storage mode on any of those scanners, nor is it stated in any of the Uniden owner's manuals as being a necessary part of the process. Barring a defective USB cable, just connecting the cable to your PC will trigger the scanner's screen to select the mass storage mode. If the card in the scanner is corrupted, or it's a newly formatted blank card and you turn the scanner on with the USB cable already connected to the computer, it may not go any further than the "SD Card File Error" screen. If this happens, leave the scanner on and just disconnect the USB cable and then reconnect it to reach the mass storage screen.
Granted, the first time a new user sees the "SD Card Error" message it can seem like a daunting, scary and complicated process to recover, and some feel a sense of panic thinking that their expensive scanner is now damaged, or that they will they will cause damage to it when trying to recover. Rest assured, in the event that a simple SD card failure happens, no harm has come to the scanner and you can not cause any harm to your scanner during the recovery steps... even if you make errors during the process. Just start over again and carefully follow the steps.
The entire process of formatting the card, running the "Clear User Data" process, and then writing to your scanner from Sentinel to re-populate your programming data on the card is a straight forward procedure that only takes a few minutes to get you up and running again from start to finish. The comment of "fighting with it for several hours" just doesn't make any sense. Using an external card reader to perform the steps will be even faster (having faster read/write speeds) than doing it in the scanner. It's not too often that an SD card becomes so corrupt that it can't be reformatted and re-used, but having a couple of extra new cards on hand is always a good idea.
Aside from having your scanner's customizations and programming kept in Sentinel, the best advice by far, for the fastest and simplest way to recover is to prepare in advance for when an SD card error might happen. Make complete backups of your SD card! When you have your scanner programmed the way you want (or whenever you make changes), copy the entire contents of the SD card to another formatted card, or copy the contents to a dedicated folder on your computer. Then if you get the SD card error, you can reformat that card and quickly copy the backup files from your computer to it (or to a new card) and be done with it, or just pop in the backup SD card that you already copied the files to earlier. If you travel with your scanner, keep 1 or more spare, programmed cards with you. If you have a card failure when not near your PC, you can be back up and running in a matter of seconds.
And a couple of things that seem to frequently trip up new users..... when a new (or newly formatted) blank card is put in the scanner without any files on it, the scanner will still power up with the "SD Card Error" on the screen. The scanner will only boot up completely once the card has the files put on it from the clear user data process, or from your backup files copied to the new card. Also, when Sentinel's clear user data process is used on a new (or newly formatted) blank card, the first window that opens on your PC after starting the process won't recognize that card until the "Display all drives" box is checked.... just be sure to select the correct SD card (if you have more than one connected to your computer at the time).
And to repeat some very sage advice that @ofd8001 recommended above.... don't over think it!
bigbear518
Missouri
Thanks for all the replies guys. I know there are obviously several ways to resolve this issue. However, some seem to still have trouble with their cards even after they've done some of the things, like reformatting or even buying a new card. Yeah it took me a couple hours to figure out the process I listed above. I figured out how to do it with the Scanner and not have to remove the card to reformat or spend money on a new card I didn't need to. The process I listed will get you up and running in less than 10 minutes. I'm not saying you have to do it this way its your choice, it worked for me. I'm retired so I had time to mess with it.
