have one trunk and one conventional system enabled by quick keys. i can hear only slices of transmissions as the scanner keeps scanning. programmed by radio reference using arc-xt pro. scanner won't stay on a call.
Also, check to make sure none of the Priority Modes are enabled which will cause the transmissions to be interrupted.i can hear only slices of transmissions as the scanner keeps scanning.
To begin with, set squelch to 2. I use ARC-XT also. If you attach your RSF programming file(s), I will check it (them) for problems. You will need to right click on the file and Send to Compressed (zipped) folder to be able to attach it. Click on Attach files and open the zipped folder. Here is a PDF file which will answer all of your questions about using quick keys:have one trunk and one conventional system enabled by quick keys. i can hear only slices of transmissions as the scanner keeps scanning. programmed by radio reference using arc-xt pro. scanner won't stay on a call.
thanks for the quick response. i have L/O all the police and sheriff. i am also using broadcastify cell scanner app.and it's busy / busy... i should be able to program those the same as who ever is feeding that service??? but the main problem is "won't stop scanning"have one trunk and one conventional system enabled by quick keys. i can hear only slices of transmissions as the scanner keeps scanning. programmed by radio reference using arc-xt pro. scanner won't stay on a call.
I have not set any priorities and after a reset they should be off. i will check that.Also, check to make sure none of the Priority Modes are enabled which will cause the transmissions to be interrupted.
thanks for taking the time to help.To begin with, set squelch to 2. I use ARC-XT also. If you attach your RSF programming file(s), I will check it (them) for problems. You will need to right click on the file and Send to Compressed (zipped) folder to be able to attach it. Click on Attach files and open the zipped folder. Here is a PDF file which will answer all of your questions about using quick keys:
update... sending my rsf. i have group 3 of system 1, and groups 1 and 2 of system 2 active using quick keys.To begin with, set squelch to 2. I use ARC-XT also. If you attach your RSF programming file(s), I will check it (them) for problems. You will need to right click on the file and Send to Compressed (zipped) folder to be able to attach it. Click on Attach files and open the zipped folder. Here is a PDF file which will answer all of your questions about using quick keys:
Waiting for the files.update... sending my rsf. i have group 3 of system 1, and groups 1 and 2 of system 2 active using quick keys.
already sent to youWaiting for the files.
I will be checking them.
did you get that?I will be checking them.
nope. lets try this...one system active (conv) three groups active group 3 has the weather channel. the weather is a constant broadcast, so it stops on group 3 (weather) now i get slices of the weather it's still scanning groups 1 ans 2. " it will not stop scanning" does the same with trunking system. i have reset the scanner and loaded the modified files.While scanning, do you see NFM or the control channel frequency on the third line from the bottom? If you see NFM, there is a good chance you are experiencing simulcast distortion.
thanks but i am not using cc or pri's or alerts. i entered the weather freaq myself. while it is slicing the weather broadcast, there is no other hit or audio. "it just keeps scanning and slicing"Close Call & weather alert priorities are turned off?
