BCD325P2 SCANNING
tedtedpil
rock island, illinois
If you hold onto any particular frequency does the "slicing" stop?
when i HOLD the weather (sys 2 grp 3) it plays weather, then advances to sys 3 grp 1, after a delay it goes to a cc whick i have L/O, then it goes to a public safety (30.8600mhz) which i did not program, and holds there. ??? also cc was on by default i guess...went through all cc and turn it all off. now waiting for some activity.
tvengr
Well Known Member
Baltimore County, MD
If it stops on weather for a while and then begins scanning again, it sounds like you may have scan delay set to a negative value.
tedtedpil
where is my reply to you? i refreshed this page and it is not here. i just sent this reply and my prev reply is now showing. what gives?
I can see it just fine...
just checked, still on pos 2. the only delay setting i can find is in sys. opts
wtp
Port Charlotte FL
hit menu, program system, hit yes
scroll to the system, hit yes
scroll to edit sys option, hit yes
scroll to set delay time, hit yes,
scroll to 2 (it is under 1 sec, there is no negative 1), hit yes
hit scan
tedtedpil
i think turning off cc made a differnce. except now some calls are good and some are jerky and intermittent. AND...the virtual control in ARC-XT PRO is logging calls but not breaking squeltch. the logged TGID's are the same as on my cell phone feed.
tedtedpil
most of the time ARC-XT PRO will log calls but no audio. then it will log the same TGID with audio. and the audio is choppy. hard to get the full message. but turning off cc i think did make a difference. that's all for tonight.
tedtedpil
don't know about this forum...have to send a reply to see my latest posts. if my scanner isn't enough, i have to learn how to navigate your forum site. i start to get some help, then they just disappear. and nothing. sorry to be a bother.
tvengr
Well Known Member
Just click on Forums at the top of the page to refresh. You will not see anything new until you do that.
wtp
Port Charlotte FL
do you have the closest tower to you programmed in ?
2 (2)041 (29)East MolineRock Island, IL851.4125851.9375c852.4625c852.9875c853.875
2 (2)042 (2A)Illinois CityRock Island, IL851.425851.950c852.475c853.8875c
2 (2)043 (2B)Rock IslandRock Island, IL851.4875852.325c852.850853.375853.950
2 (2)044 (2C)East Moline CCRock Island, IL852.350852.875c853.400c853.975c
2 (2)046 (2E)Moline 700Rock Island, IL770.21875770.71875c773.79375
2 (2)047 (2F)Moline 800Rock Island, IL851.3625851.8875c852.4125852.9375853.4625
tedtedpil
thank you but how would i use these? in a 325 where would they go?
wtp
Port Charlotte FL
i would just make different systems and see if some get hits, or which ones don't.
then delete the dead ones.
