GTO_04
DaveIN you may have a point. Under Device Manager what should my com1 settings be? I only have 1 com port BTW.
GTO_04
GTO_04
GTO_04 said:DaveIN you may have a point. Under Device Manager what should my com1 settings be? I only have 1 com port BTW.
GTO_04
yfdgricker said:I upgraded to the latest firmware for the BCD396T and I must say, the Ohio MARCS system sounds much better. No problems with it so far.
DaveIN said:How would you compare it to the PRO-96 audio?
That is a sad statement for Uniden.Universaldecoder said:I had a Pro-96, and now the BCD396T. Pro-96 has much better audio, period.
hotdjdave said:That is a sad statement for Uniden.
So, does this update improve the audio at all? So far I have seen mixed stories.
stewart00311 said:Well I was very surprised to hear how my 396 was receiving Nashville today, figured I would take the plunge and update. Well I will be rolling back to the previous firmware update.
Setting in my shop listening as I always do I was lucky to keep the TG's stable enough to listen.
I still appreciate Uniden continuing to support the radio, but this update just was not for me.
Any other's listening to the Nashville system seen any other changes if they did the update.
mikeh said:will this frimware update help with Virginia Statewide Agencies Radio System (STARS)
thank you for the input
mike h
I meant it is sad for someone to say that a RS/GRE sounds better than a Uniden, not that the RS/GRE is better. I would much rather have my BCD396T. Personally, I don't own a RS/GRE (anymore), so I have nothing to compare my 396. Actually, it sounds fine to me, except for the occasional digital sounding P25 and trunked problems, but the audio seems fine.Universaldecoder said:I've noticed in the past that if you use a bigger speaker and place it in a bigger box you get much better range of volume, and sound.
If you take the same speaker and stuff in a smaller shallower box the sound will degrade.
So maybe the size of the Pro-96 has a lot to do with it. Anyhow, sad? For who? Uniden just earned $500 of my hard earned money! And like anything the 396T has it's short comings, but I'm still smiling at having one.
