- Joined
- Sep 11, 2003
- Messages
- 57
I have recently found that when connecting my BCD436HP to the BC-SGPS kit via the Uniden connector, that while GPS is displayed on the screen, my location is not being updated. I have ensured that location control is set to on, and serial port is set to 9600.
With my Indiana-based favorite list on and GPS unplugged, I set the zip code to CA (90210) and verified on the screen that there was nothing able to scan. I then connected the powered GPS to the scanner, an observed the GPS indicator come on. However, there was no change, and the scanner still displayed nothing to scan. I let it set for some time to make sure that the GPS receiver had locked.
Is there a possibility that the GPS puck has died? I would assume that the GPS indicator on the screen wouldn't come on if it was not receiving data. In fact, one test I did was to disconnect the cable from the puck while it was connected to the scanner, which cause the GPS indicator to go away.
Any ideas on how to fix this?
