BCD436HP wont connect in serial port mode
Tim-B
Down South
I am using ProScan with various scanners for programming and control and for recording new talkgroups, etc. It works well with all the scanners except my 436 and 536. When I connect the programming cable to the scanner and press the decimal/no button for serial connect mode the computer gives me a "baw baw bomp" denial tone. I am running windows 7 on a laptop. I went to windows device manager and it says all usb ports are working properly an that the drivers are up to date. I have usb to serial drivers installed for other older scanners and they work fine with the same laptop. Any ideas of what I can try?
ProScan
Software Provider
Ontario, Calif.
First check that you have the correct driver. Here is the page that has the link to the driver.
http://info.uniden.com/twiki/bin/view/UnidenMan4/BCD436HP
Next click the Auto Detect button located in the Comm. Port settings of the menu and see what happens. Alternatively, go to the Windows Device Manager and note the comm. port number and set the ProScan comm. port number the same.
Tim-B
Down South
Dude you rock, thank you, that did it. Now instead of "baw baw bomp" I now get "ba BOMP" and the scanner is working fine with proscan.
WD6ABC
Santa Ana, Ca.
Selection on startup via Serial port
It sure would be nice to be able to select remotely the serial or USB Mass storage choice. Then the radio could be programmed remotely.
Anyone know of a way to do that??
Using ver 1.18.0
WD6ABC
John B
WD6ABC
Santa Ana, Ca.
Remote Commands-UpMan
UpMan, is there a newer command listing available??
I only found the one on the Uniden WiKi site. MSM not listed there.
Thanks !
John Bush
WD6ABC
UPMan
In Memoriam
Arlington, TX
MSM was just added a week or two ago. I don't have a revised reference.
WD6ABC
Santa Ana, Ca.
New Remote Commands
Appreciate any other new commands.
Writing software for remoting the x36HP scanner & hopefully the SDS100.
Thanks again
John Bush
Rem Scan Products
