BCD536HP Analyze, RTC, Other Update (1.06.10)
UPMan
In Memoriam
Arlington, TX
Just released v1.06.10 for your pleasure.
BCD536HP v1.06.10 Revision Notes (4/10/2015) This firmware version includes the following updates, enhancements, and bug fixes:
  • Improved scan rate
  • Avoided an issue where a packet length of a specific number of bits locked up the USB driver.
  • Fixed a issue that blocked updates if the Wi-Fi module is not connected.
  • Implemented Analyze modes
  • If RTC battery fails, allows user to continue operation using a temporary time setting
  • Blanks the clock display if temporary time setting is used.
  • Changes the default names for Favorites Lists, Systems, Sites, and Departments to be based on sequential numbering.
  • If temporary time setting is used, confirm before proceeding to:
    • Recording
    • Discovery mode
    • WX Alert Mode
    • WX Priority On
  • If temporary time is used, Weather Alert logs are not deleted after expiration time.
  • If temporary time is used, Weather Alert expiration times are not shown.
  • If temporary time is used, Weather Alert logs are deleted after power cycle.
  • If temporary time is used, change the Set Clock menu operation.
  • Improve P25 voice quality
