BCD536hp Discovery Freezing
andybutler
Maine
Hi,
Has anybody else had an issue in discovery mode when it stops on a frequency and never resumes and the word DAT Appears near the signal strength? Not sure what DAT icon means anybody got any thoughts or advice? You can menu out ok but the other buttons do nothing, turning the knob which usually restarts the scan does nothing as well.
I have the latest firmware installed.
Andy
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Yes, that's been reported here before.
The scanner has found a P25 control channel and will not move past it. UPMan has said that the next firmware release will fix this problem.
andybutler
Maine
Thanks Mike.
I'm using the discovery to work out the CTCSS/DCS code for an item in my favourite list is there any way to get the scanner to display the code when scanning a favorite list if I set the drop down to CTSCSS/DCS Search?
