whooey
I am still having problems assigning light alerts to conventional channels. I read the manual on page 48 and it sounds like it is with the scanner. Can you set the light with the Sentential software? I am finding it very frustrating but it should be easy.
Bill
Open Sentinel.
Go to EDIT>EDIT FAVORITES LIST>SELECT FAVORITE LIST>HIT OK
Left column, expand system you want to set light for. Next select department from left column. You will see the channels on the right (main screen).
You will see the 11th column it says Alert Light. Click on the channel under this column you want to set the alert light for. A box will pop up and there you select your color and flash pateern (I prefer solid).
Note if you want to set a whole dept to the same color, you can copy and paste the whole column.
Hope this helps...
