boxcom
Hey gang, I'm at an absolute loss here. I am having issues finding a Trunk system on my 536HP. I have programmed it to go into my favorites list called "Northern NJ Fire" In this favorite list, I further broke everything down by County. I have the conventional and trunked systems within a county in the same system. Thus, Bergen County (Conventional) is System 00. Bergen County Trunking I have also listed as System 00. The scanner shows them in the scanner just fine. The same holds true for all the conventional and trunk systems I have for Essex & Union Counties. Here is the issue. I tried to do the same thing for Morris County in System 06 (conventional and Trunk). My scanner shows the conventional system and scans it, but the Trunk system is no where to be found ANYWHERE in the scanner. I've reprogrammed the scanner numerous times. I've deleted the Morris County Trunk data file in Sentinel and re-entered the Trunking info for Morris County, figuring the file was bad. Nothing. I made sure all the Quick Key info was programmed the same way for the other trunking systems. This damn data file just won't show up on the scanner. Hell, I even added Middlesex County trunking system and the scanner had no problems and shows it as in the scanner. Any ideas? I've been racking my head for 2 full days.
