Bcd536hp
n4anz
Hampshire TN
I have a Uniden BCD536HP scanner. I performed an update on the scanner last week, and since the update I have no longer been able to hear Vanderbilt LifeFlight. I was receiving Vanderbilt LifeFlight normally before the update, but I have not heard any of their transmissions since updating the scanner. I would like to know if something changed with the system, frequencies, talkgroups, or database information that could be causing this issue. Not sure what has happened Any help would be greatly appreciated
n4anz
Hampshire TN
Hi. Have you tried pushing your config to it again?
If I also forgot to mention that I have this configuration programmed into the sds200 also and I'm not hearing it on that scanner either when I was hearing it on both of them
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
n4anz
Hampshire TN
I am not around the Sentinel softwares this time but I can do that later this afternoon for your question about the SDS 200 I also did an update on it
buddrousa
Vandy has moved to the TACN Trunking System 100% they no longer use their old radio system.
Uses talkgroups 48250 and 50992. Conventional appears to no longer be in use (6/26)
This also has been discussed here in outer threads
n4anz
Hampshire TN
The TACN trucking system is what I was receiving to them on. once I did the update I no longer hear them on the 536 HP or the sds200
