BCD325P2/BCD996P2: BCD996P2 analog response time
Bonkk083
Union, SC
What does analog response time do I see it on proscan under general settings
ProScan
Software Provider
Ontario, Calif.
See this document and the Adjust Audio AGC section
Easier to Read BCD996P2/XT Digital Scanner Manual
Scroll to 'Response Time' and press E/●.
This parameter determines how frequently the AGC factor updates. Decreasing this value makes AGC respond faster, but could result in "pumping." A higher value decreases the response time.
jtwalker
Gettysburg, PA & Fenwick Island, DE
You seem like a curious hobbyist, so I would suggest you read the manual, cover to cover, a couple times like I did. Then read through every post on the forums here that contain ‘996p2’ like I did.
Then if you still have questions, come back with them but I suspect many of your basic questions will be answered.
Bonkk083
Union, SC
Some of it I don't quite understand like priority settings yes or yes for priority plus and DND, which would be better to use
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Again this is explained in the manual Bob (Proscan) linked & JT alluded to but I'll give you the nitty gritty. DND = Do Not Disturb which means if there's an active transmission going on while this close call mode is active then said transmission won't be interrupted or "Disturbed" in favor of a priority transmission until the scanner resumes scanning
Bonkk083
Union, SC
What is the difference between dnd and priority plus, I read this part several times more than anything else
JethrowJohnson
I love P25
Marietta OH
Priority DND (Do Not Disturb) scans all channels and checks priority channels every two seconds, but  not while it's receiving a signal.
Priority Plus scans  only the priority channels.
Priority scans all channels and checks priority channels every two seconds and will interrupt lower priority or non-priority channels.
Bonkk083
Union, SC
With priority plus if you set quick keys will 1 overide 2 and so on
ProScan
Software Provider
Ontario, Calif.
When I set quick keys it only shows 0-9 but on the manual it shows 0-99 am I missing something
Are you referring to GQKs?
Per the manual
Understanding Quick Keys
There are 100 'System/Site/Search Quick Keys' (0-99) and 10 'Group Quick Keys' (0-9).
Bonkk083
Union, SC
Per the manual
I think that's what I'm doing wrong, for using priority plus does each channel have a quick keys are just for sites and systems
wtp
Port Charlotte FL
i have never used any quick keys. i just lock or unlock what i want.
i have just about every setting set to auto ar default.
and i enjoy my radio set my way.
priorities just interrupt what you are listening to, unless they are set to DND.
i also find it easier to carry another radio, or the wife has one, to avoid missing stuff.
she listens to the sheriff only( id scan), and i listen to it all(id search)
yes, you should set the radio up the way you want, but you don't have to change every setting in the radio.
the people who designed it spent some time on their settings so you would not have to.
