BCD325P2/BCD996P2: BCD996P2 - DMR
partyguy816
Texas
Perhaps this is an easy fix, I don't know. I paid for the DMR upgrade, entered the code, and everything seemed good. I used ARCXT Pro to add a DRM group (not exactly sure of the terminology), but it will not pick up any radio traffic. On my SDS100, I had the same issue, which was resolved by selecting the service types.
Does this 996P2 have something similar, and I'm just missing it?
hiegtx
Mentor
Dallas, TX
What system, or agency, that you are trying to monitor?
Did you create a DMR system, with sires and talkgroups, or a One Frequency Trunked system, or just entered your frequency as a conventional channel? Since you indicated that your SDS100 also had a problem until you corrected the service type, this is in the database?
tvengr
Well Known Member
Baltimore County, MD
It doesn't show encrypted. It is a DMR trunked system. Make sure that the proper LCN's, Channel ID numbers, and Color Codes are programmed for each frequency. All of the frequencies must be entered, not just control channels.
DMR Tier III Site Frequency Table
LCNCh IDFrequencyColor Code
271543854.3875c1
271544854.3875c1
421843856.26251
421844856.26251
5011003857.26251
5011004857.26251
5571115857.96251
5571116857.96251
6371275858.96251
6371276858.96251
6751351859.43751
6751352859.43751
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
Is it encrypted?
If the talkgroups were encrypted then they'd be listed under the Mode column as "TE" as opposed to "T" unless they recently made the switch and no one noticed / submitted the update to the database...
partyguy816
Texas
Thanks, tvengr. I'm mostly certain all the channels are there since I used software for programming, but I'll check in a while when I get home from work.
partyguy816
Texas
It turned out the LCN numbers did not correctly pull over with ARC-XT. At least it was something simple.
Thank you.
tvengr
Well Known Member
You may want to send an email to Butel Software customer support and explain exactly what happened. They are very responsive at correcting problems and would want to know if the software is not working properly. There could also be a problem with the way the Radio Reference database is formatted. In either case, they will get to the bottom of the problem and take care of it and let you know the final solution.
tvengr
Well Known Member
Second reply from Butel: good catch , we will fix this in the next build. - If you ever have a problem with Butel software, let them know. They are very responsive.
palmerjrusa
Frederick
Concur, they are.
Have a lot of their software...
  • Like
Reactions: RRR
partyguy816
Texas
Sorry for being nonresponsive here; I've been slammed at work this week and just now coming back here. Thanks for reporting it to Butel, and it's good to hear they will provide an update at some point.
tvengr
Well Known Member
Under the Help tab in ARC-XT, select AutoCheck for Updates. The software will let you know if there is a later version available when you start it.
