BCD996P2- Proscan software
alittleweird1
North Bend, WA
Our area just updated to P25 Phase 2. I got a Uniden BCD996P2 scanner. I'm using Proscan to program it, but It's not working. I used RR within Proscan to add the 2 TG's that I want, but it doesn't work. Proscan has 2 different options, P25 standard trunk and P25 one-freq trunk, I tried looking up the difference but couldn't find one. I also added more frequencies than the control that RR loaded just to make sure that wasn't the problem. I'm probably just missing a setting somewhere that i haven't found.
alittleweird1
North Bend, WA
Trying to scan P25 Phase 2. I'm seeing "NFM" on the screen, but not always.
Just trying to monitor my local police. Had no issue till it went to Phase 2. I bought the Uniden BCD996P2 cause my old scanner wouldn't cover it.
ProScan
Software Provider
Ontario, Calif.
Can you post your database file or a screenshot of the tree.
ProScan
Software Provider
Ontario, Calif.
Just trying to monitor my local police. Had no issue till it went to Phase 2. I bought the Uniden BCD996P2 cause my old scanner wouldn't cover it.You may be
You may be scanning a conventional system too because of the NFM showing. P25 Phase 2 doesn't do conventional.
wtp
Port Charlotte FL
Snoqualmie​
12/15/20 - Reported to be using speech inversion for privacy
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
155.9475WPXN230BMSnoq PD LocalPolice LocalFMNLaw Talk
and i sent a PM if you look at the top right of this page.
tvengr
Well Known Member
Baltimore County, MD
I suspect the OP is trying to scan the PSERN P25 Phase 2 trunked system. If you see NFM, that means you are having problems decoding the control channel. You should see the control channel frequency displayed. It could be due to selecting an out of range site or simulcast distortion.
Snoqualmie​
DECHEXModeAlpha TagDescriptionTag
12434dbTIssaq/Snoq PDIssaquah/Snoqualmie PD DispatchLaw Dispatch
17736edTSnoq PD Tac1Police Tactical 1Law Tac
17756efTSnoq PD Tac2Police Tactical 2Law Tac
alittleweird1
North Bend, WA
Snoqualmie​
Now that I've changed to "ID search", I can hear traffic, but not the ones I have programed.
tvengr
Well Known Member
You need to have the site or sites that the Snoqualmie PD units affiliate with to be able to hear them. Squelch should be set to 2. You can program all 8 sites and assign a different system quick key to each one. You will then be able to easily select a site or sites by pressing their numbers on the keypad. Here is a PDF file which will answer all of your questions about using quick keys:
  • Uniden Scanner Quick Key Instructions DMA.pdf
alittleweird1
North Bend, WA
Squelch is at 2 and got the quick keys setup and still getting NFM. I added a few more frequencies than RR added in hopes to pick up a closer tower.
ProScan
Software Provider
Ontario, Calif.
Don't put freqs from other sites into that site. Just reimport and it should look like this. Latter, you can use the Google Maps feature to see the coverage area on the various sites and delete the sites far away.
