BCD396T/BC996T: BCD996T First time programming.
F6twistersrwindy
New to scanning. Loving it so far 😃
Ohio
Hey. I have a BCD996T that has been half reprogrammed No trunking added just local frequencies. I want to start from scratch but I have never programmed a scanner or used one. Ive read the manual. I understood most of it. My question is, I am using windows 11 laptop and I need advice on what programming software to use. I want to be able to add updates easily as they come out. User friendly to because I have never done this. Also I'm having a brain fart understanding Uniden I-Call. The manual said it is to pick up local one on one comunications. What is that? Then I read from google saying I-Call is the same as the CloseCall feature. I thought Closecall was picking up emergencies close to home? I using this as a base unit only. All advice welcome. I'm just starting. 🙂
Solution
I was saying that a lot of what is listed in the database for NWORPSS is seldom to never used. I mentioned node255 because if you use ( the talkgroups seen in the last 24 hours ) tab it will give you a pretty good idea of what is really active. I used Sentinel to program my SDS200. I have Proscan but didn’t have any issues with Sentinel so I stuck with that. Proscan will import all of NWORPSS. You can then just avoid the talkgroups that aren’t used. The Lucas County Simulcast is what was given your 996t problems. I have only the Lucas County Simulcast site programmed. I still receive Wood County and Fulton County talkgroups
F6twistersrwindy
Ohio
If you listen to the playlist it’s only a couple seconds delay. You’re able hold onto any talkgroup on the playlist.
You’re also able to access the archives and listen to past transmissions. I also have a FreeScan file for NWORPSS if you decide to try and program your 996
TY. I'm going to use the proscan software when i program the scanner. Is that a file i can dl from rr ?
F6twistersrwindy
Ohio
The file ProScan creates when you store all the data you want to send too the scanner. I don't know what the file extension would be- other ProScan users can help you with that
Mike
Ohhhh ok. So its what I will gather as far as what i want to listen to & how I want it organized?
F6twistersrwindy
Ohio
OK. Thank you so much for offering. I'm going with Proscan though & I just seen on here that the 2 softwares cant be mixed.
tvengr
Well Known Member
Baltimore County, MD
If you take the offer of the FreeSCAN file to program the scanner, you can download the scanner into ProScan once it is programmed and you will have it in both FreeSCAN and ProScan. That is an easy way to convert files.
K4EET
Chaplain
Severn, Maryland, USA
@F6twistersrwindy, when you get ProScan, or even the Uniden Sentinel software, the FIRST thing you want to do is READ the scanner’s current programming information and save that file in a safe place. That way, you will have the current programming if you ever need to go back to it.
Then you can create your own programming however you like. As you create the new programming, save that file under a different name so as to not overwrite the file you saved in the first paragraph. But I’m sure you know all about how to organize files on your computer. 😃
<edit> Now that I think about it, the Uniden software to program your scanner may not be called Sentinel. Can someone correct me if I’m wrong. TIA!
F6twistersrwindy
Ohio
Yes Ty. Unfortunately the scanner was only half programmed. I took it to be programmed but it got messed up. I posted a video of what the scanner was doing and and someone replied
"It looks like he did not program the Quick Keys for you to easily turn things off, nor programmed the OhioMarcsIP Trunking System and just programmed you a bunch of Conventional frequencies that are hardly ever used"
So here I am lol
K4EET
Chaplain
So here I am lol
Not to worry. All of us here are ready to help you program your scanner. Don’t hesitate to ask…
GILLIG40
Northwest, Ohio
If it only has conventional frequencies on it, then it wouldn’t have the simulcast distortion that you will get on NWORPSS. I think someone messed with it. Jerry wouldn’t have just programmed Conventional Frequencies in it.
F6twistersrwindy
Ohio
I’m pretty sure that’s the way Jerry programmed them. He didn’t want to confuse people. Mine was always set to ID search . I didn’t even know what ID scan was until I started looking at these threads.
Oh. No. This was last week. It worked after Jerrys cb shop. But this guy last week left out everything that the scanner needed to connect or something.
This is the reply from someone who saw the video I positedof the scanner endlessly searching.
"It looks like he did not program and Quick Keys for you to easily turn things off, nor programmed the OhioMarcsIP Trunking System and just programmed you a bunch of Conventional frequencies that are hardly ever used"
tvengr
Well Known Member
Here is a PDF file which will answer all of your questions about using quick keys. Print it out and save it for your reference.
  • Uniden Scanner Quick Key Instructions DMA.pdf
