BCD396XT/BCD996XT: BCD996XT Help
Bonkk083
Union, SC
I bought a used BCD996XT and noticed while scanning a P25 system that the signal bar has all 5 lines for maybe an hour and then no lines for maybe two minutes and I have changed three antennas tried a Remtronic, telescopic and a outdoor antenna, I had tried the ID priority on and off still the same, Is this how it should operate for a P25 system and what could cause that issue, I don't know if it's this model it has the 1.06 firmware believe it was the last one for this model
richardbritt
State of NC
Northeastern NC
Have you looked at the system you are wanting to monitor in the database here to see if it's encrypted? If you see signal bars you're getting a good signal.
Regards Richard
Bonkk083
Union, SC
Regards Richard
Yes no encryption, should the signal bar be visible the whole time while it's scanning id
richardbritt
State of NC
Northeastern NC
The Uniden BCD996P2 is what you will need for the SLED system in SC. Depending on what you want to specifically listen to, it might also be encrypted. Look for DE which means full-time encryption. No scanner will be able to receive those talkgroups.
Regards Richard in Northeastern NC
StoliRaz
£uck Encryption
Palmetto 800
Palmetto 800 the Union site
Palmetto 800 system is listed as a Phase 2 P25 system in the database. The 996XT isn't capable of receiving phase 2 systems. You need at least a BCD996P2 (P2=phase 2) or its handheld cousin the BCD325P2. SDR with the proper software can also decode it.
Bonkk083
Union, SC
It says Phase 2 but it's really Phase 1,
Whiskey3JMC
Simulcastylvania, TE
That scanner can not pick up phase II P25
Ah, but talkgroups in Union County (and system wide) are FDMA (mode "D") so the 996XT should work just fine on said talkgroups although the system is Phase-II capable. If talkgroups were to transition to TDMA (mode "T") at a later point in time then the 996XT would be rendered useless
wtp
Port Charlotte FL
Palmetto 800​
System Type:Project 25 Phase II
2 (2)087 (57)UnionUnion851.750852.2875c852.800c853.075c853.450c
2 (2)091 (5B)Tinker CreekUnion771.56875771.84375772.14375772.46875c774.71875c
hope he has the closer one.
49001bf69DUnion Co SD DispSheriff DispatchLaw Tac
49041bf91DUnion Co FD DispFire DispatchFire Dispatch
49066bfaaDUnion Co EMS DisEMS DispatchEMS Dispatch
49381c0e5DUnionCityPD DispUnion (City) PD DispatchLaw Dispatch
RoninJoliet
ILL
On my 996XT on a full bars system it sometimes drops to two bars and back to five and this is what Upman would say is "housekeeping " of the scanner,...The same system sometimes reverts to Phasell and when it does the signal bars stay at five BUT the frequency which is normally 773.33125 changes to 781.5475 and there is NO audio because the 996XT does not recognize P2
wtp
Port Charlotte FL
Ron, i thought 781 was an input frequency..? or a mistype !
RoninJoliet
ILL
It's the frequency that shows up when my 996XT and RS197 are trying to show a P2 system radio transmission ,....
RoninJoliet
ILL
This happens on Grundy County here in Illinois which is on the Illinois Starcom System,...The system is P1and P2 , when a shift uses all P2 radios the Sheriff TGs are all good on the 996P2 but what you see on the 996XT is that 781 frequency with NO audio just sitting there ,....
Bonkk083
Union, SC
I have the id scan priority on should pri show on the display like it does for conventional the only thing I see is a P beside the frequency
RoninJoliet
ILL
If you turn Priority on at the "System " and on the TG that's what you see, "P"
