Today we released new firmware for both the BCD436HP and the BCD536HP, as well as an update to the Sentinel software for the BCDx36HP models.
BCD436HP/BCD536HP Firmware Changes:
To apply the Sentinel update, download and install the new version of Sentinel (you do not need to uninstall the old version). You can download the new version by clicking here: http://info.uniden.com/twiki/pub/UnidenMan4/BCD536HP/BCDx36HP_Sentinel_Version_1_05_00.zip
- Added an option to turn off Replay recording, to minimize SD card wear/corruption issues if you do not use this feature.
- Changed the startup sequence when a USB cable is connected. Now, the scanner will default to Serial mode if you do not make a selection within 10 seconds.
- Changed the startup sequence so that a bad SD card will not result in an apparently dead scanner.
- Added support for the Replay OFF setting.
