BCT15X 2-second pause
kc0ikk
Myrtle Beach, SC
With the BearTracker on or off, I still get a "gap" when I'm listening to activity on my BCT15X. I'll even open up the squelch and you can distinctly hear a 1-2 second gap in conversations. Anyone have this problem?
Yes, this problem happens with free scanning and also with programmed systems.
Marion County, Iowa
Sounds like you might have a priority on. Check to make sure you don't have any weather on priority or any channels/systems on priority. Also if you are running Close Call it will cause the audio to cut out unless you are in DND (Do Not Disturb) mode. Some things to start with anyway. Hope that helps you find your problem.
