Edelweiss
Author of: Scanning the UK Airbands with the Beast
Hi, when on Hold I try to access a channel in a different system. The channel has a confirmed number tag allocation, checked by using scanner menus and also via ProScan that I use.
I can't get this to work. Does the to-be-accessed system need to be active?
If I enter say 6.60 MENU according to the instructions I get "System Number Tag 6.60 is not Stored" "Press any key".
When I go into system 6 and access it directly it works, also proving it is programmed. Any ideas? Probably a stupid user error.
Mike
Mike
