Try unplugging the AC adapter and run off of battery power. The fact that you are hearing a pop indicates there may be a leakage path between the AC source and the antenna or power ground, That can set up a time constant and cause pops at a regular interval. Anytime you are dealing with multiple pieces of equipment connected together can cause all kinds of audio problems. If your mixer has a grounded power plug, try plugging it into an adapter to disconnect the ground pin. You can try the same thing if your scanner AC adapter has a grounded plug.
I have multiple radios on the same antenna system (elaborate filtered/amplified/multi-coupled setup) and none have issues, including the one the 15X replaced.
None of the attached equipment has a grounded plug except the UPS everything is plugged into.
I have multiple radios on the mini-mixer (which is USB powered) and none have issues, including the one the 15X replaced.
I’m not looking to fix this because as I said I’m sending it back. The existing setup has worked flawless for many, many months now so I highly doubt it’s a design issue. I was just curious if anyone has had audio issues with their 15X.
